Old 06-19-2005, 11:41 PM   #1
Green Machine
Green Machine's Avatar
Soundproofing between gas tank and cab question ?
A quick look tells me there is about 1/2 in. gap between gas tank and rear of cab(please correct me if I am wrong). I know there is the expensive stuff, but could I use some generic 1 inch foam rubber and compress behind the tank, tank removed of course. Would that help reduce sound level any ? or would the expensive stuff be better ? And does it really matter if you put anything between the tank and rear of cab at all ? You have the tank and the cover and the seat there already to suck up some sound ? Any thoughts ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-20-2005, 12:21 AM   #2
wichitawings
insulation between seat and tank
I had a cardboard cover of sorts that I glued some cheap black carpet from auto zone too on the front and on the back I glued some old carpet padding I had. I used spray on glue and it barely fit between the seat and tank but it is a lot quieter.
wichitawings is offline   Reply With Quote
Old 06-20-2005, 12:33 AM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
You can get new carpet padding at home depot and use that as sound barrier and it works too!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 06-20-2005, 01:15 AM   #4
Green Machine
OK, I guess what I'm really asking is does it do any good to put something between the gas tank and the back of the cab, given you have the other stuff in front of it?
Also if you put something behind the tank, does additional stuff like the tank cover padding give any additional improvement ?? Thanks
Old 06-20-2005, 07:30 AM   #5
JimKshortstep4x4
Talking
The back of the cab wall is like a big tin noisy partition so anything that you glue onto it will help. We cover the wall and the the gas tank with a good sound absorbing material and it definitely makes a difference.
Jim
