06-20-2005, 04:50 PM | #1 |
10 bolt differntial for C20
I still have not figured out how to search the threads so I must ask.
Today I looked at a 68 C20 and it had a 10 bolt differential. It is sort of round and the bolts were not evenly spaced. What differential might this be? What gears are available for it. Can 5 or 6 lugs axles be purchased for this differential? Thanks in advance. Tim
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-20-2005, 04:58 PM | #2 |
II Timothy 4:2
Sounds like an HO52. The gear ratio is probably a 4.10, which is the lowest you can get. You can only use 8 lugs with them.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
06-20-2005, 05:12 PM | #3 | |
Thanks. Is there a market for a HO52? This one has been serviced within the last 30 days with new seals. Would these backing plates bolt to a half ton differential? If not the HO52 has new brakes with new drums.
06-20-2005, 05:21 PM | #4 |
II Timothy 4:2
It's pretty hard to break them, which is good because it's pretty hard to get parts for them. No, nothing will interchange with a 1/2 ton.
