Old 06-19-2002, 09:59 PM   #1
Mountain Man
Attn Longhornmail
I noticed that you have indicated on another thread that the TH350 modulator is adjustable. Can you tell me where it is located on the tranny , and is it just a slotted screw that I would turn to the right to shift at a higher rpm. I feel that mine shifts too quickly into 2nd and into third especially.
Thanks in advance.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-20-2002, 12:27 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Kinda sounds like the kick down cable is not hooked up to me. Many are left like this after an intake or carb swap, and it goes for so long that it is forgotten.
However, there is a chance I am way out of line on that. Here is a pic of the mod...it is on the passenger side of the tranny...if yours is nastier than mine...then clean it. (J/K) Just follow the vac line, should be a hard line untill the last 6 inches or so.
Sorry it is so blurry, I just ran out and layed in tranny fluid for you.
To adjust it, pull the rubber hose off (where indicated on my pic) and there should be a hollow flat head screw in there...to raise the shift point, screw it in. (righty tighty applies here)
Old 06-20-2002, 09:39 AM   #3
ckhd
ckhd's Avatar
Sweet! I was 10 minutes from asking this same question.
The 'burb is the first slush-box I've owned, and I'm kinda lost when it comes to adjustments. BTW, my kickdown cable is hooked up.
Thanks for the answer I didn't have time to ask!
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-20-2002, 05:16 PM   #4
Longhorn Man
LOL, no problem boss!
Old 06-20-2002, 09:12 PM   #5
Mountain Man
Hey Longhornmail. You the man!!!
I sure appreciate all the tips you have provided. Hope I can repay the favor some day.
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 06-20-2002, 09:56 PM   #6
Longhorn Man
Don't mention it boss, just hope I set you right and you get your rig goin.
