Old 06-19-2002, 10:12 PM   #1
68 with 350 TPI
68 with 350 TPI's Avatar
Question for you guys running TPI's about the fuel pump.
Are any of you running a inline eletric pump with a 350 tpi?
If so what kind and where did you get it.
Also how did you run the return line?
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 06-20-2002, 01:22 PM   #2
68 with 350 TPI
ttt
Old 06-20-2002, 02:34 PM   #3
jflem3
jflem3's Avatar
options
I have a burb so I'm going to run a late model 73-91 burb 32 gallon tank and they have a drop in pump and sending unit for the factory FI trucks.(need to reverse the fill tube direction,weld before you put any gas at all in it or BOOM!!)
return line:
Just order another fuel line from classic line or inline tube adn run it just below the factory line route it into a vent hose or run it up the filler and route it into the upper neck of the gas filler.
sdsefi.com has a schematic for running a low pressure to fill a holding and a high pressure pump from the holding tank in the engine compartment to fuel rail.. might help
Jim
Davisburg, MI
69 Camaro SS LT-1/6-spd
71 C-20custom deluxe burb 402/400
(gonna get back to it)
72 C-10base burb 350/3-spd
79-VW Scirocco GT-3 race car 2.0L/5-spd
02 chevy suburban LT Supercharged dropped on 22's
jflem3 is offline   Reply With Quote
Old 06-20-2002, 03:46 PM   #4
E.R. Leonard
Be sure pump is the lowest part of the fuel delivery system. The pump pushes the fuel and has a hard time sucking. If pump has no fuel for any amount of time it will shorten it's life. The fuel actually cools the pump.
67 C10 LT1 project step side
68 C10 250 short step side original
69 CORVETTE CONV 427, 4spd, 6-pak
99 CORVETTE CONV
78 chevy 2wd blazer
Angleton, Texas
E.R. Leonard is offline   Reply With Quote
Old 06-20-2002, 07:03 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Fuel pump(GM short #EP286)+filter(Fram part#G7333)mounted inline on the Passenger side frame rail.
5/16ths steel brake line used for the return line.Mounted to the drivers frame rail.
I have the return connected to one of the vent tubes but this is giving me trouble when filling the tank.I'll be moving the return line to the filler tube or be soldering a return port into the fuel gauge float assembly.
Hope this helps
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-21-2002, 02:22 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Bobbyk - what is your engine out of?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-21-2002, 05:57 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I have the same one Bobby does except my filter is on the inlet side. Don't have any problem drawing suction. Did at first, but a hand vacuum pump conquered that. Just hook it up to the fuel rail test fitting(with valve stem out) and pump til you get fuel. Reinstall valve stem and off you go. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-21-2002, 06:37 PM   #8
Stepside
Gasser
I bought a Rock Valley stainless tank for the rear. They put the high pressure pump in for the LT1 I'm doing. Yes, it was expensive, but what's another year?
Where is Wingate NC, from the Triad?
Stepside
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 06-22-2002, 01:12 AM   #9
BobbyK
BobbyK's Avatar
Yukon,The intake and runners are from a 91-92 Camaro.22lbs injectors for the SBC350,Corvette electronic distributor(with coil in cap).The eng. is my old one.I just traded the old carb and intake for the new TPI intake.
Old 06-22-2002, 03:31 AM   #10
68 with 350 TPI
Wingate NC is just outside of charlotte NC.
