Rear coil-overs
I have a 70 c10 longbed and I would like to use this system. I was just wandering if any one uses it and what thay think.
coil over suspension |
1968 C20 Vortec Beast
Looks like a pretty nice system, I haven't used it myself though. They need something like that for the C20.
![]() Join Date: Jun 2002
You might contact BowTieMan, he posted this pic, not sure if it is his truck or someone else's.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
thaks for the pic I will try to pm him
That set-up in the pic looks like Classic Perf Products coil-over kit. Check their web-site for details.
FWIW, when I inquired about that set-up they said it was strictly for normal 'un-loaded' conditions. They didn't recommend hauling any heavy loads (trailers and/or a fully loaded bed).
It is the cpp kit i was just wandering how it handled. I dont plan on haulin i just want a good smooth reliable ride.
zach |
Dave's not here, man
I am also interested in the question above. How much of an improvement is this over lowering springs? I have 5" drop springs but I switch to coilovers if the improvement was dramatic.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
