Old 06-21-2005, 07:44 PM   #1
hilljob26
hilljob26's Avatar
hood latch problem
i installed a billet grill on my truck,but as you can see,there is no way for me to open the hood once it is closed,i thought about running a cable from the park brake lever seems how im not using one,or even a system kinda like the old chevelles where you open it from under the bumper,i could use a little insight if anyone has any
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 06-21-2005, 07:50 PM   #2
Steven B
Steven B's Avatar
I know Wes and maybe some other vendors have a relocation kit for that use
Steven B is offline   Reply With Quote
Old 06-21-2005, 07:56 PM   #3
aitch
aitch's Avatar
Looks like a good time for a in cab hood release. Not hard to fab.
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 06-21-2005, 08:15 PM   #4
hilljob26
hilljob26's Avatar
thats what i thought,just run a cable using my ebarke latch,heck,nobody would even know,now i just have to figure it out,any ideas,heack,anyone have a cable long enough
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 06-21-2005, 08:56 PM   #5
bagged91
Out draggin'
bagged91's Avatar
There was a thread dealing with a remote latch using an 88+Chevy hood release handle & cable. I think it ended up in the FAQ section. Looked good under the dash. You could also do the same thing using a hood release assembly from say an early-mid 70's Caddy. That may be more pleasing to the eye as the handles would match better.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 06-21-2005, 10:39 PM   #6
Hart_Rod
Hart_Rod's Avatar
I think this is the one your talking about Bagged:
http://67-72chevytrucks.com/vboard/s....php3?t=136797
Bagged -- check out my new purchase (I'm trying to follow in your footsteps!!).
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4556940861
Rob
Hart_Rod is offline   Reply With Quote
Old 06-21-2005, 11:18 PM   #7
70chevc10
70chevc10's Avatar
same thing happened to me when i put my billet grill in. until i realized what that extra bar was in the box. it bolts on to your existing hood latch, and what you have to do is reach under the bumper, push up on the bar,, and hold it while u open the hood. pain in the ass kind of, but atleast no one will know how to open your hood you might be able to fab one up yourself. ill go snap some pics of mine real quick for you.
70chevc10 is offline   Reply With Quote
Old 06-21-2005, 11:35 PM   #8
70chevc10
70chevc10's Avatar
the first pic is a top view. the bar on mine is bent becuase when i was putting it in, it didnt look like it would work, so i bent it so it would clear everything. im sure if you made one straight it would work fine. the last two show from the bottom, just one bolt holds it in to the existing hole on the hood latch. hope this helps!
Old 06-22-2005, 01:58 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks! That's good to know since I too will be installing a billet grill shortly....
Did you get the 3.73 gears yet? Greg
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-22-2005, 02:08 PM   #10
Putter
More Cowbell....
Putter's Avatar
Just an idea, but why can't you use the in-cab release method that I put in the FAQ section, and simply cut off the "J" hook that sticks up above the release (the second 'safety' catch)? I mean, use only the hole in the latch with the stem that is on the hood. That would make it 100% in-cab operated. Then just walk to teh front and lift the hood. I have NEVER heard of anyone's "properly adjusted" hood popping open on them while driving, so the safety "J" catch isn't really a big issue.
Like this: (Before & after) Then maybe just weld the slot for the removed "J" up and grind it flush & smooth!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-22-2005, 04:23 PM   #11
hilljob26
hilljob26's Avatar
thanx guys,a think thats what i will do,dad just bought a 94 that he is going to part out,so i will use that stuff
mocwon-no,still no gears,just cant seem to find a good enough deal yet
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
