Mark
transfercase input
I came across a small problem maybe someone has had the same problem .I have a 77 gmc short bed 4x4. I lifted it 4 in on susp. and 3 on body.Now the shift lever on my new process 203 transfer case hits body. Anyone know how to get around thic prob ty
Look at every day as a holiday, some just better than others.Build what you got be happy with what you have ![]() Last edited by slingin mud; 06-21-2005 at 09:09 PM. |
Professional Grade
Can you extend the rods somehow?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Mark
thought of that would have to custom make it was hopping someone knew a better way
Look at every day as a holiday, some just better than others.Build what you got be happy with what you have ![]() |
california fill
cut the body
![]() I have the same setup except with a np205 case and I modified the shifter.. its quite easy w/ the 205's shifter design.. the 203 is a little more complex :/ pc |
