Old 06-21-2005, 11:41 PM   #1
elvis50138
elvis50138's Avatar
passenger upper hinge
I need to adjust the passenger side door on my 86 C10. It has some cheap aftermarket doors installed by the previous owner. I need to move the upper hinge on the pillar on the passenger side forward. I removed the door and saw that there are two bolts I could loosen from the outside. There is a third that appears to be bolted in from the interior. I removed the dash but could not find this bolt. It appears to be behind the dash metal. Is this correct? I figure there must be someway to loosen this bolt. Any suggestions?
elvis50138 is offline   Reply With Quote
Old 06-22-2005, 12:44 AM   #2
Bowed
you do not need to remove the dash . If you feel around on the inside behind the hinge you will find a hole in the inside sheet metal and the bolt will be in there . On at least 1 truck have seen those round pop out covers covering the holes , yours may be one .
Bowed is offline   Reply With Quote
Old 06-22-2005, 03:12 AM   #3
ureckme
ureckmefixit2@cox.net
Hay just remove the glove box not the hole dash.
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
