Old 06-22-2005, 02:46 PM   #1
Americanrider
Wanted: HD front spring pak for '67 K20
I'm in the middle of a front axle swap and would like to upgrade my front leaf paks. Right now I have the stock 2 leaf pak. Looking for a 3 leaf pak, or an aftermarket 2 or 2.5 inch lift. It measures 44 inches eye to eye and 3 inches wide. I Would prefer to find this west of the Mississippi since shipping will be costly.
Thanks!
Americanrider is offline   Reply With Quote
Old 06-22-2005, 08:40 PM   #2
gregbr
Senoir Member
gregbr's Avatar
Would you be intersted in selling the factory springs if they are the same as a 1/2 ton? Shipping to 29730. I have a used set of 4" lift front springs off my 1/2 ton 67 4wd (will need bushings, has u bolts). Brand unknown, medium sorta stiffness. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 06-22-2005, 11:46 PM   #3
ZOOMY
'67 K20 springs
I have a set of lift springs on the front of my '67 K20. I was going to just take a leaf out to bring it down some. Maybe you can just add a leaf. I did the add a leaf thing to my '69 K20 25 years ago & it's still going strong..............Zoomy
ZOOMY is offline   Reply With Quote
Old 06-23-2005, 02:26 PM   #4
Americanrider
Gregbr: I'd like to stay close to stock or no more than 2.5 inch lift. Thanks!
Zoomy: The trouble is finding one to add, nobody has the wide 3 inch stuff that is shorter than the bottom spring.
Old 06-26-2005, 02:51 AM   #5
Americanrider
TTT anyone have this setup laying around?
Old 06-30-2005, 10:16 AM   #6
sakohntr
sakohntr's Avatar
add a leaf
All fords used 3 inch wide leafs. Go find a used one and saw it to your desired length. Make sure you put the centerhole in the correct place.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 07-02-2005, 01:16 AM   #7
Americanrider
Still needed!
Old 07-02-2005, 01:48 PM   #8
Erl
Erl's Avatar
I am going to remove a set with 3 springs from my 68 in a couple of months. It has the 850 lb 305V6, so the truck had an extra factory spring. I am putting a 2 inch soft ride lift on. PM me if you are interested.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
