Old 06-22-2005, 04:12 PM   #1
Bowtiefreak
Bowtiefreak's Avatar
Widening wheel tubs for bigger tires?
I know this has been asked before but seeing how the search is down i am looking for some help. Can someone shed some light on this subject. I have seen posts before with pics. Does anyone have a link to any posts on this subject?
Thanks a bunch Ron.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 06-23-2005, 09:26 AM   #2
Bowtiefreak
Anyone?
Old 06-23-2005, 10:03 AM   #3
Joe67
67 is sold
Sounds like you want to 'mini-tub' the truck
I don't have any links or pics.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-23-2005, 10:06 AM   #4
67chevemall
67chevemall's Avatar
I used galvinized sheet metal down the sides and rounded pieces over the wheels.
tack welds and rivets.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-23-2005, 10:36 AM   #5
redhead69
fugedaboutit
redhead69's Avatar
I want to do mine too. Was thinking of cutting them down the middle.. adding about 3" of material.. cutting bed floor to fit.. drill new holes and re-install. Be aware of where bolts are running along the frame... I think if you cut too much out- those bolts will be a PITA to get back in (your new tub will be directly over the frame.) Oooh.. just noticed you got a wood floor.. might be more difficult.
Currently truckless
redhead69 is offline   Reply With Quote
Old 06-23-2005, 11:48 AM   #6
'70_402
'70_402's Avatar
Just go the junkyard and buy some wheel tubs from another truck and use then as donor metal.
'70_402 is offline   Reply With Quote
Old 06-23-2005, 11:49 AM   #7
Bowtiefreak
Yep, looking to do a mini tub. I was also thinking of getting another set of tubs and cutting 3-4 inches out of the center section. This would look more like the factory appearance. I have seen one thread before with this done but can't find it with the search down. I think boardmember Purs was also going to do this.
Old 06-23-2005, 11:54 AM   #8
70 longbed
I am looking for the old post as well. There was a good one out here not long ago; explained how much to cut out of the bed, how much to add to the wheel well, etc.etc. A really good post, that when found could be added to the stickies for mini tubbing.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 06-23-2005, 12:43 PM   #9
Bowtiefreak
Yep, I hope someone has it.
Old 06-23-2005, 01:04 PM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
these...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 06-23-2005, 01:12 PM   #11
Bowtiefreak
FirstGen-
Yes, it was from that post I believe. This was one of the trucks I remember. Thanks Do you have that post saved by chance?
Old 06-23-2005, 01:21 PM   #12
HuggerCST
HuggerCST's Avatar
I don't have the link, but here's another pic for you. I think if I were doing it, I would find some donor tubs, cut yours on one side, cut the donors on the other side, resulting in only one seem, or weld to fill.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 06-23-2005, 02:05 PM   #13
Bowtiefreak
I have a two pics of that truck too but no link. You are right on the money with the one seem idea.
Old 06-23-2005, 03:34 PM   #14
A few 72's
A few 72's's Avatar
Ill throw one in...
A few 72's is offline   Reply With Quote
Old 06-23-2005, 05:44 PM   #15
tomatocity
tomatocity's Avatar
As the other members said, use tubs from a junkyard or where ever. I will just use number so don't think the are correct measurements. If the original tub is 18" and you want to make 24" tubs. Take two left tubs and cut one 12" from the driverside and cut the other driverside tub 12" from the right. Weld them together and you have a 24" driverside tub. Do the same for the passengerside tub. If you are really good you will overlap the center piece for strength. I won't attempt to explain that.
Thanks a bunch Ron.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-24-2005, 09:31 PM   #16
BowTieMan
BowTieMan's Avatar
How big of a tire could I fit if I mini tubed my 70? Anybody got some picture of the tires on a mini tubed truck?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 06-24-2005, 11:31 PM   #17
Ridgeback
I have a nice set of wheel housings that have already been increased in width. I plan to sell them in the next couple of weeks. If you are interested I can send you some pics along with measurements after the 4th of July.
Ridgeback is offline   Reply With Quote
Old 06-25-2005, 12:12 AM   #18
SCOTI
SCOTI's Avatar
Yes, splicing 2 tubs together will have only 1 seam to be filled, but it also limits the depth of the tub.
Stock fleet tubs are 11.5" @ their widest point (from the bed wall to the mounting flange) & only 8.5" @ the point where the tub starts to form the 'crown' or the rolled edge. If you splice 2 together, you have to cut them where they're still 'flat' or approx 8" from the flange that bolts to the bedside. This means about 18~19" max width when splicing 2 together.
As you can see in the first few pics, those tubs are 21" wide which is why there are 2 seams. The stock tubs were split & a flanged 9~10" piece of metal was added. They can also be bolted in just like factory because the bed floor was also kicked up for pumpkin clearance.
The truck in the first pics had 31x18.5 Mickey-T's on 15x14 wheels under those 21" tubs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-25-2005, 02:39 AM   #19
tomatocity
tomatocity's Avatar
You are so correct. Who made the flanged strips? They ought to think about selling the strips or tubs made to order.
How much did you narrow the rearend to fit the wheels and tires?
Old 06-25-2005, 12:56 PM   #20
SCOTI
SCOTI's Avatar
I cut them to the right width & my buddy had a machine that 'rolled' the bodylines & proper flanges for welding. The overlapping also increases the strength of the seam.
The rear end wasn't narrowed. It was a stock length 67-68 12 bolt coil rear. I used custom widened steelies. I didn't narrow it because I knew in time the larger diameter wheel/tires I desired would be available. This was done many years ago as I've be messing w/this thing for almost 20yrs .
No frame mods other than removal of the factory bumpstop. This was done w/just widened tubs & widened wheels w/the proper backspacing. No pics as the wheels/tires are long gone & replaced w/some 20's (which have also been replaced ).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-25-2005, 05:28 PM   #21
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
I would be interested....Send me pics if you can and a price.
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-25-2005, 11:39 PM   #22
71Dragtruck
71Dragtruck's Avatar
I have 15x12" rim's 6.5" backspace, with 28/14.5/15 tires and lot's of room left. My tubs are a bit narrower than the ones shown, they are made out of 2 sets of fenderwells. They are about 1" away from the frame, to go wider I would have had to add a strip so the would line up with the next rib in my steel box. It was either go wider than the frame or a bit narrower. Even with them a bit narrower I can narrow my rearend 4" a side, go with 15x12 4.5" back space, for a more dished look, and a much larger tire and they will still tuck under ( future plans ).
71Dragtruck is offline   Reply With Quote
Old 06-26-2005, 12:22 AM   #23
Hart_Rod
Hart_Rod's Avatar
tubs
OOOPPSSS! Sorry wrong year!
Hart_Rod is offline   Reply With Quote
