Old 06-22-2005, 07:01 PM   #1
grayw0lf
Wheel wobble? Can't get rid of it?
My right front wheel has always had a bit of play in the camber. (I have new tie rods, ball joints, wheel bearings). I went to get an alignment the other day & the old mechanic told me he thought my hub was worn (wallowed) out. He said the inner bearing race was probably spinning it was so worn.
I didn't notice this at all when replacing the wheel bearings & races. He showed me & there was definately a problem, he's not just trying to sell me junk. He tightened the wheel bearing, but to no avail. Way too much movement up/down (not side to side).
Has anyone heard of this? Or am I missing something? Races not fully set? Ball joints loose? I looked while it was up on the lift, but didn't see anything. (I somehow missed this when doing wheel bearings).
Thanks,
Clueless.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-22-2005, 07:03 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I went through this myself...find a new hub before you need a spindle too.
Old 06-22-2005, 07:05 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i would take his word for it since he does alignments all day long
just my .2 cent
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-23-2005, 08:47 AM   #4
grayw0lf
Thanks LonghornMan, I was hoping for your feedback, even if you are a Newbie to the site with only 00008 posts.
How would I know if I need a new spindle too? Am I gonna have to Mic it?
05' Dodge Neon
94' Seadoo SP
Old 06-27-2005, 10:27 AM   #5
grayw0lf
Thanks Longhorn.. You & the old mechanic were right. I pulled the wheel to see that the outer wheel bearing freely rotates on it's own. It moved around just a slight bit, but 15" out from the center, that 2mm becomes 2 inches.
Off to the junk yard I go.!
05' Dodge Neon
94' Seadoo SP
Old 06-27-2005, 05:51 PM   #6
Longhorn Man
your spindle OK?
Old 06-27-2005, 06:15 PM   #7
grayw0lf
Originally Posted by Longhorn Man
your spindle OK?
I sure hope so! Do you know of any way to tell? It appears to be fine, no cuts or gashes. I'd almost need a known good spindle I can set beside it to compare with.
I'm not sure if the larger diameter base that the inner bearing race sits on should be at a sharp right angle, or a slight taper for about the first 1.5mm. Perhaps I should get out the digital camera & take some close-ups.
05' Dodge Neon
94' Seadoo SP
Old 06-27-2005, 06:26 PM   #8
Longhorn Man
pics would be nice.
The fisrt thing you'd notice is discoloring. Lots of blue and purple.
Old 06-27-2005, 09:50 PM   #9
Gramp'sGold70K20
New
Gramp'sGold70K20's Avatar
Forgive me Graywolf if you think I'm stealing your post. I ran into the exact same problem. Replaced everything you did and ran into the same "wobble" on my right front tire. Is the solution the same on a 4 wheel drive?
Gramp'sGold70K20 is offline   Reply With Quote
Old 07-05-2005, 11:20 AM   #10
grayw0lf
Hey Longhorn (or others),
Do you know if a hub from a '66 C-10 will fit my '70 C-10? I have a friend who just pulled some off & that would work out quite well.
05' Dodge Neon
94' Seadoo SP
Old 07-05-2005, 11:21 AM   #11
grayw0lf
I don't know if it is the saem problem or not, but I do know that for the 4x4's, you can buy a new hub at your local parts store.
05' Dodge Neon
94' Seadoo SP
Old 07-05-2005, 09:33 PM   #12
Longhorn Man
I would pull the hubs and compair the two for a good bit, checking bearing diameters and all that good stuff...but I would imagin the old one would work.
Old 07-06-2005, 01:43 AM   #13
Richard
In a pinch I have taken a punch and peened the spindle to keep the inner race from spinning. It can be done for the outer race area as well. Not a real long term fix but will last a bit if the spindle or hub is already damaged.
Richard
