![]() Join Date: Jul 2001
Casting Number ?
After doing a bit of "hoss tradin' " I came up with a couple pieces I'm not sure of the original application.
First one is quite apprently a Quadra-Jet intake manifold as it has the small primarys and beer can sized secondaries. It is most definetly cast alumninum with the casting number # 14014482 GM 2F. Second one is a standard shift cast iron bell housing with the casting number # 3815891 and H114 raised casting on the edge near the tranny mount. In a second depression alongside the casting number is "GM 1" . Any one who can decipher or identify these items for me. Is there a good on-line GM casting source I can bookmark? Also a good pocket sized booklet that can be used at a swap meet? Any help or input is much appreciated. Thanks.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
I have a listing for an intake that is 14014432 for a 1981 350 4 barrel.
Don |
After looking at the intake again it may well be 14014432. On the front rh side of the thermostat housing it has the numbers "9/6/79". It has a EGR pad on the right hand side behind the carb base. On the under side the numbers " 432 " are cast into it along with the letters " EGR " at opposite end. Does your info give the application of the intake? Guy at work who is quote -- "supposed to know" -- unquote says it was used on Z28 Camaros with the 350?
No thats all I had on it but it very well could be a z28 intake because I have seen quite a few like that on those.
Don |
Cantankerous Geezer
Stumbled across a database in my files. Doesn't have intakes, but did include bell housings.
Bell housing is from a 63-66 V8 truck, 11". Date code H 11 4 would be Aug 11, 1964.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
