Old 06-23-2005, 12:16 AM   #1
Ogier
Chopper/Painter
Ogier's Avatar
Talking What a colossal PITA...
Ok, here was the issue:
69 Chev with a transplanted 472 caddy motor in it. Runs great more filling.
Over heats. Average temp running down the highway was around 230-240.
When I put it in the truck, I didn't shove the engine back to the firewall. I left about an inch and a half for clearence.
I was not able to run the factory clutch fan.
Also, Oil pressure starts at around 40PSI and drops to zilch when it is really hot.
Solution:
Two days and lots of sweat later, I shoved the engine back one inch and took the non-clutched fan and mounting spacer from the 77 that I just got and after milling the spacer down 5/8 of an inch, installed it and removed the electric fan that I had in there.
Now Temp stays at 185 regardless of driving conditions.
Oil pressure starts still at 40PSI but only drops to about 23PSI at temp(I think the bypass spring may need replacing...
Problem solved. What a PITA....
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-23-2005, 12:39 AM   #2
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
couldve been alot worse, seems like you did alright. good job!
milehightoyz is offline   Reply With Quote
Old 06-23-2005, 05:58 AM   #3
GMC AMI
GMC AMI's Avatar
Wink
Solution:
Caddy main bearings are worn down and have too much clearance, very common in these motors. Tighter when new than Chevy bearing clearance.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-23-2005, 06:38 AM   #4
Swapping motors can cause PsITA.You`re doing good now.
