Old 06-23-2005, 12:01 PM   #1
TWOKEELYA
TWOKEELYA's Avatar
Steering question
Hey Everyone,
My steering darts left and right at speeds over 25, I wouldn't call it wandering, my old truck use to do similar, but it was slower movement. This is a quick movement. Where do I start, steering box? rack? any good test for either?
Specifics: 68 lifted C10 W/33 inch tires, good tread, power steering, retrofitted leaf springs.
Richard
Not all who wander are lost
TWOKEELYA is offline   Reply With Quote
Old 06-23-2005, 05:25 PM   #2
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I'm thinking ball joints..........any play when you wiggle tire/rim when off ground?
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 06-23-2005, 05:28 PM   #3
krue
Designated A-hole!
krue's Avatar
Don't forget to check tie rod ends.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-23-2005, 05:28 PM   #4
'70_402
'70_402's Avatar
You need a steering stabilizer that mounts to your front axle. lifted trucks with big tires have a problem with this and that stabilizer will solve it.
'70_402 is offline   Reply With Quote
Old 06-23-2005, 05:49 PM   #5
ckhd
ckhd's Avatar
All good suggestions. If it's the original '68 dana 44 front axle, then it has bearings and not ball joints or king pins.
Anyway, the bearings in the steering knuckles, wheel bearings, tie-rod ends, drag link ends, & leaf spring bushings can all do what you described. A good plan is to jack it up and shake the heck out of the wheel and see if you can find anything. Another trick I've used is to put it on the ground and have someone push the front-end back and forth (side-to side) while I was crawling around looking at stuff.
Personally, I would look at the steering box last (exept to make sure the steering arm is tight).
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-23-2005, 06:47 PM   #6
TWOKEELYA
TWOKEELYA's Avatar
Thanks for the bad news, it does have a steering stablizer, the truck was mostly restored but never maintained after the restore, and things like bjoints and trod ends are suspect just for that reason. Heck, the headers didn't have any header gaskets on them and they were missing several bolts as well.
