Old 06-23-2005, 12:48 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
Windshield washer pump doesn't work...
I can't figure this one out. Originally my trucks's wipers weren't working. So I replaced the entire assembly from a scrapyard find, washer pump and all. Now I have wipers that work great, but can't get fluid to spray on the window. So then I figured I'd rebuild the pump assembly. Did that last night with an autozone rebuild kit, and exactly the same problem. I even swapped out the pump from my old wiper motor assembly, still nothing.
Any ideas? I don't even know what to check next?
Jakes-66-K10 is offline   Reply With Quote
Old 06-23-2005, 12:50 PM   #2
farside847
farside847's Avatar
does it click or make any noise at all? If it does its a plumbing problem. If not it might be electrical.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-23-2005, 12:57 PM   #3
Jakes-66-K10
Yeah, I can hear it trying to work. But no water flowing, I should be able to put my finger on the hose that leads into the washer reservoir and feel a vacuum right? Maybe I can try hooking an air compressor up to one end of the hoses, to tell if they are plugged up...
Old 06-23-2005, 01:32 PM   #4
kaycee
kaycee's Avatar
I had to put a aftermarket pump by my resevior to get it to pump,I did the same as you with no luck
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 06-23-2005, 01:37 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The rubber seal on the "piston" inside the washer pump might be so dry rotted that it can't pull a vacuum. I had that happen to me with about 6 different pumps.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-23-2005, 01:43 PM   #6
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
If the pump actually works (wich I doubt) pull a line off of the nozzle and try it then. Nozzles get plugged.
It's tough to find a good used washer pump. The re-build kits only come with the check valves and washers. The main problem with em is the lil cam lobe on the pump wears down and makes it VERY hard to actuate. I've figured out how to re curve the cam lobe. Next problem is the cylinder walls are usually gouged and water will leak past the piston into your cab. I have thrown away good money trying to figure out how to rebuild this pump cheaply. Played with later years/models looking for a good donor parts. Everything was trash.
Best bets. Junk it. If you are stuck on factory (like me) go buy a new one. My non-delco one was $29.00. You have to get it from one of the Chevy truck vendors. the parts houses do not have a the mechanical one. If you don;t mined a generic solid-state pump, you can buy them everywhere for around $20.
Edit: Trust me. It will be cheaper in the long run.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
