Old 06-23-2005, 07:35 PM   #1
PLavelle
PLavelle's Avatar
Front drum to disc conversion kits
Can someone point me in the direction of some front drum to disc conversion kits for me '67 Chevy Stepside? Any recommendations?
1967 Chevy C10 Stepside - Vortech supercharged - Currently for sale
PLavelle is offline   Reply With Quote
Old 06-23-2005, 08:13 PM   #2
bigarmzz
bigarmzz's Avatar
there's a guy on the board here that sells the kits....i cant remember his name though.... ....hell, i'm lucky to remember what i did yesterday though....
i'm wanting to do the conversion on my 87 rear end too
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 06-24-2005, 07:56 AM   #3
1low1967
1low1967's Avatar
I just went out to the junkyard and picked up a crossmember from a 78, it is 5 lug, power steering and disc brakes for a lot less than a conversion kit, but i'm working on a tight budget... the crossmember bolted right in except for 2 bolt holes that had to be redrilled.
1low1967 is offline   Reply With Quote
Old 06-24-2005, 08:46 AM   #4
Hart_Rod
Hart_Rod's Avatar
Disc Brakes:
http://67-72chevytrucks.com/vboard/s....php3?t=156778
Rob
Hart_Rod is offline   Reply With Quote
Old 06-24-2005, 11:36 AM   #5
PLavelle
PLavelle's Avatar
Rob, I would have bought that from you but I decided to go with a 5 lug setup. Did you buy your 5 lug setup from Classic Industries too?
Old 06-24-2005, 01:35 PM   #6
Hart_Rod
Hart_Rod's Avatar
PL,
I bought my setup from Stan @ ECE, he did me right. I ended up converting everything to 71-72 (tie rod ends/drag link/spindles), however you can buy spindles that work with the 71-71 rotors/calipers and with the 67-70 tie rods and drag links. I just wanted all to match. Sorry about bugging you again about the parts, I thought I had sent you a previous e-mail but wasn't sure. I may just use those parts on a the 70 Burb I just bought (factory 402 with rear air). Have a good weekend.
Rob
Old 06-25-2005, 10:31 PM   #7
PLavelle
PLavelle's Avatar
No problem, Rob. Thanks for the help. Who is ECE?
Old 06-25-2005, 11:32 PM   #8
Hart_Rod
Hart_Rod's Avatar
Early Classic Enterprise. www.earlyclassic.com Stan was extremely helpful every time I called.
Rob
Old 06-26-2005, 01:11 AM   #9
PLavelle
PLavelle's Avatar
I'll give him a call on Monday. Thanks again for the help.
