Old 06-23-2005, 07:51 PM   #1
vern350
like a rock
vern350's Avatar
how big of tires will fit on 4x4 3/4 ton suburban
i got a stock 78 4x4 3/4 suburban. I was wondering what size of tire i could fit, without any rubbing and any problems? 31"/32"33"???
Thanks Brian
vern350 is offline   Reply With Quote
Old 06-23-2005, 09:33 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
hmmmm i would think that you should be able to get standard to wide 31s such as 31x10.50 works easily, had them on my 76 c1500, or slimmer 32s on there.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 06-23-2005, 10:46 PM   #3
Redburban
i have 33x12.50 on my half ton 4x4 burb.
Redburban is offline   Reply With Quote
Old 06-24-2005, 06:31 AM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
All depends on wheel width. 33s will normally fit without rubbing on an 8" rim but will rub on a 10" wide rim. Same story on 32s in my experience. 31s will not rub on either size rim.
79Silv4x4 is offline   Reply With Quote
Old 06-24-2005, 07:01 AM   #5
Also depends on how much your leafs have settled.Also depends on use and how much travel you will need.
Old 06-24-2005, 12:27 PM   #6
vern350
like a rock
vern350's Avatar
its in need of new tires, so i'm thinking a little more aggressive and bigger. May purchase a lift kit, for clearance and for bigger tires. With a lift kit, can you still carry the same payload?
Old 06-24-2005, 10:06 PM   #7
screwballl
Tonawanda 454
screwballl's Avatar
depends on the kit, some reduce it... the manufacturer of the kit should have some more info on that. sometimes you can get a 2-3" body lift for the bigger tires and keep the towing hitch/assembly on the frame without too many problems. The only time it may affect it is if you load up the inside back of the burb...
Old 06-25-2005, 09:45 AM   #8
u2slow
Web Wheeler
u2slow's Avatar
I run 255/85R16 (approx. 33x10") on the back of my 2wd Burb. No rubbing.
I also ran the same size on my '91 crew without any lift or rubbing.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
