Brake parts question
Does anyone know a good source for getting brake drums, shoes, hardware kit and wheel cylinders for a 69 4 X 4, 3/4 ton. I have checked out both lmc and chevy duty and am running into some issues with the drums and harware kits for the 3/4 ton with 4 X 4. i may be able to get my drums resurfaced as they didn't appear to be too bad. any suggestions would be appreciated.
Keep On Truckin'
Have you tried NAPA or other local auto parts stores? I got my stuff (not 4X4) at local parts stores.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Cantankerous Geezer
Get the drums turned if you can. New ones won't be cheap. You should be able to get what you need through a local Napa or mom & pop parts store. Wagner shows BD60131 for the drum, PAB310 for the shoes, if they are 12"x2". Best if you can take in a drum and pair of shoes so they can be sure you're getting the right parts.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re:
Thanks guys
