06-24-2005, 10:13 AM | #1 |
Active Member
gas tank conversion
Hello, I have a 72 SWB 4x4 I am completing and one of my remaining tasks is to remove the saddle tank from behind the seat and have purchased the blazer/conversion tank for installation between the frame rails. I actually have the full setup for fuel filler from a 72 blazer and had intended on setting up the truck to have the fuel filler pop out accordingly on the rear bed panel. I have seen this done and it looks....well OK, but not cosmetically optimal as I would like. then I found an after market fuel filler that bolts onto the side of the sheet metal (flush mount), in the truck and car shop catalog. Does anyone have experience with this solution? Any suggestions? Thanks for your input
Jim |
06-24-2005, 02:54 PM | #2 |
I found this in the FAQ section. This is an awsome solution IMO because I dont like the fuel cell in the bed or the fuel door on the outside of the bed look. It will take some time but I think it will be well worth it.
http://67-72chevytrucks.com/vboard/s...d.php3?t=77104 |
06-25-2005, 03:04 AM | #3 | |
I like the idea of using the side marker as the fuel filler door. Earlier tonight I read that someone had done this and has a problem filling the tak full because of the low filler tube. Look at the pic that shows the tube and tank relation and you can see the possible problem. I was planning on using this and now I have to think of something else. I have a wide WB so I am thinking of experimenting with the tail light. Essence of 56 Chevy.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-25-2005, 03:26 AM | #4 | |
What parts are needed for a gas tank relocation? How much deeper (closer to teh ground) is the new tank?
