![]() Join Date: Mar 2001
Progress to date!!! Picts included
here is few picts of my restoration project.
Ramjet 350 w/fuel door and Early Classic tank under the bed. Its by no means complete, but at least things are going back together instead of coming apart.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
Sweet! Is that a supercharger?
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
Where's my beer?
Looks very nice. I like that Ramjet motor alot, should be a nice upgrade.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
67 is sold
Very nice - I wish I was half that far
computer illiterate
cool what did that tank set yah back?
72 2wd blazer 72 swb 4x4 |
Looks wayyyy sweet!!! Very clean work!!
I've always wondered....how do you get the tail gate lettering done.....hand paint, or careful back taping? ![]() ![]()
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
I think the tank was apprx $700, rather expensive, but I would purchase another if needed. The tank just bolts in using the factory frame holes, includes a sender unit. This tank cost an extra $100 bucks due to the pump in the tank manifold. Its made out of stainless, includes the mounting hardware (all of it), plus its baffled internally. This tank mounts flush to the top of the frame, meaning you dont have to remove or cut any bed crossmembers....it also includes the rear frame cross member, which must be removed if using a shortbed frame ( I dont know about the long bed frame) ECE states this is a 23gal tank, I haven't filled it yet so dont really know. I ask for an extra bung be installed near the filler neck for the purpose of a "vent" tube back to the filler neck. I am using a filler door/assembly out of an S-10. The fuel pump/strainer and fuel fittings are all extras...so it adds up quickly. I am however very glad to get the tank out of the cab.
------------ as far as the tail gate lettering goes, right now I purchased some vinyl lettering from LMC (i know, i know) but at eight bucks, thought it was worth a try....if this doesnt hold up well, I am going to paint the white in and clear over it...wish I had thought of this *before* I had the clear coat done....but live and learn. ------------
Ypur doing a VERY nice job!!! That truck is going to be a real looker when your done. Congrats!!
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
Wow, some of you guys truely amaze me with the trucks that you're turning out. I've really got to get busy!
I make Models
![]() Join Date: May 2005
Looking good...I must say I really like the color
67-72 Addict!
Another fine truck from Texas!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Designated A-hole!
That's a very nice truck you're putting together.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#13 |
That truck is coming together great!!! Congrats.
Where did you get the Headers from? What brand? Thanks.
'71 Chevy C-10 - Current '62 Imapla SS - Traded for my current '73 Nova Hatch - traded for ATC-350X '73 Chevelle Deluxe - First car (R.I.P) DEERFIELD, MA |
#14 |
The headers are made by sanderson....I purchased them from EarlyClassic. At this time, they are only "trial" fitted. The passenger side seem to fit extremely well. The drivers side on the other hand...required grinding of the casting stub on the 700R4 due to the fact the header outlet tilts in a bit more than I expected...spark plug wires will definetly require 90 deg boots with these. They seem "ok" to me, time will tell how well they hold up. They are ceramic coated and look quite nice.
Thanks for the compliments....EVERYONE!!! Will post more as I get closer to getting anything done.
#15 | |
Just Don't Stop!
![]() Join Date: Feb 2004
Just in case you don't already know this, make sure you don't do your inital break in on a new motor with ceramic coated headers - you will ruin them.
1968 C10 build in process TT LSA/6L90e/9" |
#16 |
Really? What will it do?
#17 | |
Just Don't Stop!
The temps from the inital break-in will ruin the coating. I've seen it happen before and it just causes the coating to look terrible. Not sure if it actually has any effect on the life of the coating or not.
#18 | |
#19 | |
Just Don't Stop!
more friction = more heat Can also generate more heat when you are still tuning the A/F ratio and you are running a little lean. make sense?
#20 |
Professional Grade
Exactly, when you break an engine with a bigger cam in, you are bound to be running lean. My headers never get very hot on a day to day useable basis, but when I was breaking my 355 in, those suckers were glowing like cherries. I broke mine in on some old crappy headers though, if you break in on chrome or ceramic colored headers, they turn a bluish color and just look terrible.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#21 |
OK...the sanderson instuctions state to "break-in" a new motor using either old headers or stock type manifolds....Since this motor is new, has the GM MFEI-4 computer that has both an air intake temperature sensor as well as an O2 sensor, if the engine will actually run lean during break-in and/or extra hot over everyday running as the computer should (should but may not) keep the motor in tune. Currenty I have stock manifolds which I could use, but I would need to fab up some type of temporary exhaust pipes to get thru the breakin period.
#22 |
Too many projects
very nice resto. I like that gas door.
Jim ![]() ![]() '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
#23 |
Java Mechanic
I am as green as your truck! (great job man!)
![]() This is where I am at: ![]() Last edited by panhandler62; 06-29-2005 at 10:29 AM. |
