Old 06-20-2002, 01:14 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
gas tank removal
ok, got all the boltsout and the tubes unhooked, now ow do I pull the filler neck out of the gasket? is got some gas in it still, tryinto get the ol' stepside running and the tank smells real badand some rust inte filler neck gotta nother one to go in, no new gasket though, so what is the trick?
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-20-2002, 02:02 PM   #2
JimKshortstep4x4
Smile
If you soap the gasket up you can "stuff" the seal through by working it with your fingers or you can soap up the outside of the filler tube and pull it through, without the cap on it. If the seal is bad, they available for approx. $5 from most of the vendors.
When you go back together, putting the seal in the body first and soaping the fill tube works pretty good. (Someone on the board suggested this procedure, and it works well).
Jim
Old 06-20-2002, 03:08 PM   #3
kirsten
need i say more
kirsten's Avatar
didn't we just go through this with mtdave?
*all in fun*
search out dave's name mtdave2 and see what posts come up with him in the last month- I am sure it will be there!
*1971 3/4 ton GM with a 402 Big Block*
*Sierra Grande Camper Special*
*big block environmentalist-HA*
seaangel@shaw.ca
the creation of a thousand forests is in one acorn~ Ralph Waldo Emerson
kirsten is offline   Reply With Quote
