06-25-2005, 11:35 AM | #1 |
55454
Questions for the pros
I re-titled this post for more input, the newbie title didn't draw much attention.
I have been watching this board for over five years, and have had one or more 68-72 tagged titled and insured since 1981 (never owned a 67). I am currently building a truck and would like to ask some questions, some may not seem relevent but I have over twenty years of parts and need to structure a plan before resto begins. I want to make sure the two trucks I have are original. What are or, are their more than ten differences between a BB 1/2 ton and SB 1/2 ton? Why is a 1971 cab unique and what are the differences between a 1970 and 1971 cab? Are their any differences between a 1971 and 1972 cab? Are their any cosmetic differences between a 1971 and 1972 grill? Are their any differences between a 1969 and 1970 grill? Are their differences between a 1967 and 1968 frame? Are their differences between a 1968 and 1969 frame? What is the percentage of 1967 BW custom cabs? How many different styles of ashtrays are their? Would a 1972 4x4 have an engine badge on the fender? When was factory tilt first offered and are the hazard switches different? Do truck and van tilts have the same amount of positions? When was the column flat plug adapter standard? Was their some type of power steering offered in 1967? Is the windshield stainless the same from 1967-1972? Is their a diffference in fuel lines from 1967-1972? Are all BB alternater brackets the same from 1968-1972? Are CST and Cheyenne seats the same as a C/10? Do all 1967-1972 have the tag above the key switch? What year was the wood floor an option in fleetsides and not standard? Is their a difference between the high beam indicator between 1967-1972? When was the 327 or 283 replced by the 307 or did they overlap? Was the manual over-drive only available on the 1/2 ton? Are their any other parts off a 70's van that are interchangable with 1967-1972? Is the interior light the same as a 70's international pickup? Are mid-seventies Dodge truck bucket seats the same as 1969-1972 seats? When was the 402 available for 1967-1972 and will the pitons have .030 stamped on them? What trucks were available with the high hump? What type of seat did the 1967-1968 Custom Camper walk-through cab use, did the dealer get it with the provisions for a bench and use another type seat? Is the 1967 vent window handle the same as the 1966? Thanks O/T Was the 1948 1/2 ton p/u the only one to have the gas tank under the bed from 1937-1972? Last edited by 55454; 06-25-2005 at 05:02 PM. Reason: New Title |
06-25-2005, 12:14 PM | #2 |
Here is a photo of what makes a 71 cab different it is the place where the rear view mirror mounts on all of the other cabs it is smooth.
71 & 72 cabs also had a vent on the driver side rear door pillar 71 & 72 grills are the same 69 & 70 grills are the same it is the inner grill that is different 67 frame don't have a dimple for the steering box they all have the tag above the key switch fuel lines the 71 & 72 had vent lines the other did not I hope this helps |
06-25-2005, 05:46 PM | #3 |
Old School, New Style
Welcome from Ohio.
Boy thats a lot of questions. I can probably help on some of those. I don't believe that 67 had power steering. There are two types of stainless trim for the windshield, a shallow and deep flange insert. I know some people use the side markers off the van. I have seen pictures of the late 80's early 90's flush mount van side markers used on 68-72 trucks. Walk through cab used the buckets like you would find in a burb but no console. I do believe the 66 and 67 vent handles are the same. Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 06-25-2005 at 05:52 PM. |
06-25-2005, 06:00 PM | #4 |
55454
The bucket seat info is very impressive, thanks so far guys. Do the outer 71 and 72 grills have a different paint scheme?
06-25-2005, 06:40 PM | #5 |
its all about the +6 inches
The columns all had horse shoe harness plugs through 67 - 72, the adapter was installed later, mostly in the bigger trucks that used the old style colums. Flat plugs in 10 - 30 series started in 73.
There was a power steering option in 67, it was the external ram style, like the older corvettes, VERY prone to leaking. Cab chassis trucks (67 - 72) that had the camper build up on the back had a fuel tank underneath, and all cowl/chassis trucks were so equipped too. (68 was the last year for cowl/chassis) Wood floors were never standard in 67 - 72 GM trucks fleet sides with the exception of the Longhorn, which, like the step sides, was the only way you could get it. So SWB and LWB fleet sides all came standard with steel. bb verses SB 1/2 ton trucks.... high hump was required with all big blocks EXCEPT the hand full that had 3 speeds. a heat shield on the passenger floor board for the exhaust. big block specific gearing (I think..I KNOW that to be true on 20 and 30 series trucks) HD coils remote resivor power steering if so optioned That's about all i can think of. in '70 the 396 was canned, and the 402 was used in place of it. No clue on the 30 over stamping, but I highly doubt it. 70 verses 71 cab; door jamb vent on 71, not on 72 throttle rod on 70, cable on 71 (and the hole was not the same..one or the other) As mentioned, 71 was a single year run for the raidsed mounting pad for the mirror 71 had more fuel lines, allong with the mounting provisions. High hump verses low hump... All 4X4 had high hump all 4 speeds had high hump all big blocks NOT equipped with a 3 speed manual had high humps On the GMC side, the 1/2 tons with the V-6 and automatic TH400 had high humps. There's a few variations...some swear that there big block automatic had a low hump originally...but GM says this is how it is....I'm sure some left the assembly line done wrong though. 67 verses 68 frames... 68 had provisions for the big block, which I think included slightly wider space petween the frame rails, and the flaired spot for fuel pump clearance ont he passenger forward section. Been reports of 67's ith said provisions though. 67 had no dimple for power steering gear box. (the ram set up used a non power steering gear box) some early 68's had no provisions either. Tilt started in 69 by the books, but there was a 68 shown on here recently with it and listed in the glove box....go figure. The hazzard switch being chainged to the black press button instead of the red pull button was sometime in the 73 - 87 run...I'm thinking it was 75-ish. All replacements are this way (safety feature) and should include the aformentioned adapter for flat to horse shoe plug. 2 style ash trays, nylon bushing sliders, and ball bearings. I THINK the nylon was a 67 thing. 71 cab verses 72 cab differances... the aformentioned mirror mounting pad is the only thing I know of that chainged. the 283 was replaced with the 307 in 68. The 327 was replaced with the 350 in 69 High beam indicator differences... most were a round hole, some were rectangular...I did a pole on this a few years ago, and I can't remember the outcome. I want to say 67 - 71 had round, and 72 had rectangular. That's all I can answer of the top of my head. |
06-25-2005, 10:18 PM | #6 |
Just like to part out trucks!!
Wow alot of good ???'s Tommy. I think the 71-72 grills did have a different paint scheme, the black around the headlights on the surround grill. There are 3 different ash trays, 67 only was straight on nylon, then the ballbearings, then the curved nylon slider, outer part is a bit bigger on 67's too.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
06-25-2005, 10:29 PM | #7 |
the high beam indacators 67-70 were square and 71-72 were round on the trucks i have.
06-26-2005, 02:25 AM | #8 |
Both '68s I've owned have not had the ignition key label, neither had an ACC position either.
The Internationals that I've dealt with had the same looking dome light... Gotta love the cornbinders use of everyone else's stuff.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-26-2005, 03:14 AM | #9 |
"Wood floors were never standard in 67 - 72 GM trucks fleet sides with the exception of the Longhorn, which, like the step sides, was the only way you could get it. So SWB and LWB fleet sides all came standard with steel." Longhorn man
I have a LWB box from a 71 I parted that was wood floor [Camper Special] so it must have been an option, but as Longhorn man stated above the stanard was steel floors. The Fuel tank line on my 67 is just a single, when did they go to a dual line? Again, the '71 that I parted out had a dual line from cab tank and a 3 position switch for saddle tanks. Also the 67's (and I think 68's) Had the two position key, OFF/ON/START, Later models have ACC/OFF/ON/START, The 3 position units also have a bigger dash hole & ignition bezel than the 2 position units. |
06-26-2005, 01:00 PM | #10 | |||||||||||||||
Whew, long list, I'll throw my 2¢ in"
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
06-26-2005, 07:48 PM | #11 |
Designated A-hole!
Welcome to the board from South Mississippi! Feel free to ask questions if you have any. I kill myself.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
