Old 04-07-2002, 11:32 PM   #1
Johns70
Johns70's Avatar
Post bb engine ?
just got the engine fired back up in my pickup and i can't seem to find a tick?the motor has every thing new in it, crane 270 cam, lifters, push rods, rockers,forged pistons,resized rods,reground crack,double roller chain,hv oil pump,pinned shaft,carter street strip fuel pump,and rod.but i can't find this tick rattle sounds like a loose rocker but i've adjusted them tree times and can't find any loose ones,i've got a puddle of oil in the drive way real big to prove it. any help would help don't know if this is normal for a bb or what, i drove it and it don't miss and it sounds good except this tick or rattle. thanks John
project 70 chev swb 396bb th-400 373limited slip
[This message has been edited by Johns70 (edited April 07, 2002).]
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 04-07-2002, 11:46 PM   #2
dan71
Post
I dont know if this is the problem but, Are you running a cam button? A buddy of mine has the same thing in his 454 with a button. He changed the cam and everything and it is still there. I am now running the cam he took out without a button. Sounds great! Hope this helps!
dan71 is offline   Reply With Quote
Old 04-07-2002, 11:56 PM   #3
69 longhorn
Post
Another thought,possibly a small header gasket leak?
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-07-2002, 11:58 PM   #4
Johns70
Johns70's Avatar
Post
No cam button,when your standing there in front on the right side you hear it the most, i thought about the fuel pump its goin threw a regulater but i just don;t have a clue , thought maybe sombody else might have an idea?
project 70 chev swb rebuilt 396bb{402}rebuilt th-400 3.73 limited slip
Old 04-08-2002, 12:01 AM   #5
69 longhorn
Post
You can get some noise from a fuel pump....
Old 04-08-2002, 12:10 AM   #6
Johns70
Johns70's Avatar
Post
I'm think that might be it so i might change it out to the old fuel pump and see if that helps, i'd be really pissed at my self if anything is wrong with the cam or lifters,thats only because i did all the work except the maching.
Old 04-08-2002, 04:50 AM   #7
Desert Rat
Desert Rat's Avatar
Post
When i bought the 61 Impala for my wife a few days later it started to knock i was like F,i thought it was a rod or something
Dad came over heard it said change your fuel pump holy crap that was it and it was knocking loud,couldnt believe it rally sounded like a serious internal ouchie!!!!If a tick though id suspect a small exhaust leak.
Desert Rat is offline   Reply With Quote
Old 04-12-2002, 10:59 PM   #8
PigPen
Post
John, did you find the tick ?? Have you tried listening closer with a screwdriver or anything like what your doc uses to listen to your heart ?? I use a screw driver or block of wood - not the most scientific but it works to some degree. Not a noisy lifter ? Sometimes they'll get bit of dirt in them, might try a quart of tranny oil in the block to loosen it up.
1970 Chev CST C-20 Longhorn 402,PS, PB, Buckets.
PigPen is offline   Reply With Quote
Old 04-12-2002, 11:26 PM   #9
69 longhorn
Post
To check for ex leaks, a lenght of heater hose comes in handy.......69 longhorn.
Old 04-12-2002, 11:56 PM   #10
busterwivell
Post
Had a 305 that would do the knock thing, I was sure it was a rod knock, every 10K or so. It was always the fuel pump.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-13-2002, 11:01 AM   #11
Johns70
Johns70's Avatar
Post
well the tick is still there, changed oil the oil was dirty from the moly graphite assembly lube,still need to readjust the lifters again.it doesn't tick as bad when cold but starts ticking louder when it warms up.
Old 04-13-2002, 03:11 PM   #12
bowtie
bowtie's Avatar
Post
I also had a tick in my big block and it turned out to be a header gasket leak on the drivers side bottom. The bolts were tight and it turns out that there was a small piece that chipped out and thats were the leak was.
70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
72 chev swb w/68 front clip "GM Millenium corvette yellow"
72 blazer 4x4(in progress)
1955 Chevy DelRay, 427 w/muncie 4sd, 2 dr post,
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
