Old 06-25-2005, 04:17 PM   #1
aussieskier
Audio Systems
I am looking to put in a audio system in my 78 1/2 ton to replace the single speaker and the AM radio/8-track, the latter being something I rigged up. The problem is, considering the truck came with the single speaker in the center. It is not really built for holding a nicer stereo system. I am just wondering where some of ya'll have put speakers in your trucks, assuming you have. So that I can get some ideas for where to put mine, because one speaker and an 8-track just ain't cuttin it anymore.
Thanks in advance
aussieskier is offline   Reply With Quote
Old 06-25-2005, 04:24 PM   #2
jermasaurus
jermasaurus's Avatar
Some people have a large desire for the 6x9 brackets behind the seats, my 85 originaly had 4x10's in the corners behind the seats and 3 1/2's in the dash. There were some pioneer 3 ways in boxes behind the seats when I bought the truck, and I am still using them now cause they actually sound pretty good.
Another thing to do is put them in the lower door panels which I have seen done a lot.
Crutchfield also sells replacement kick panels that hold what I think are 6"s, but they are a hefty price for what it is.
The possibilities are endless and I am sure more people will respond to your question with some good info.
-Jeremy
jermasaurus is offline   Reply With Quote
Old 06-25-2005, 04:57 PM   #3
k72516
k72516's Avatar
I forget where I saw it, but I believe some company makes kick panels that hold some speakers like modern cars.
Here's a before and after shot of what I'm talking about... I just scrounged this pic up of the net so I don't know if they make it for 73-87 Chevy's.
There's plenty of aftermarket stuff out there, just search around a lil. You might want to check out www.streetsourcemag.com or www.cardomain.com, run a search for 73-87 Chevy's and start looking at their stereo's, you might see something you like.
Go Fast - Be Loud
k72516 is offline   Reply With Quote
Old 06-25-2005, 05:28 PM   #4
aussieskier
Ok I will look into the kick panels, and I have thought about putting 6X9s in the corners behind the seats as well. Thanks for the input.
Old 06-25-2005, 05:41 PM   #5
k72516
k72516's Avatar
I know that people do that, I don't believe it to be too uncommon, but I always wondered what the sound quality was like... Can't be too good being muffled out behind the seats. I guess my point is you should keep you mid's and high's in front of you, and build/buy a nice box for subs behind you since that's omnidirectional and it doesn't matter.
In my buddy's '88 Camaro there were two speakers mounted on top of the dash, with plenty of room for some deep speakers. I would assume that these trucks have just as much room. If you've got a cracked beaten up dash just whack some holes in it and mount them there. ::full of idea's::
Go Fast - Be Loud
Old 06-25-2005, 06:02 PM   #6
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
speaker box
I built this speaker box for my truck. Cost 20.00
Behind each seat is a 8" sub pushing all this is a 500 watt amp. Sounds pretty good. I put 6X9's 1 in each door, more than enough for my 75 stepper
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 06-25-2005, 06:31 PM   #7
k72516
k72516's Avatar
Got any shots of your doors?
Go Fast - Be Loud
Old 06-25-2005, 08:47 PM   #8
aussieskier
If you had any shots of the 6X9s in the doors that would be sweet to see how you did that. As for the sub box i had planned on making one for behind the seat. In fact I have some plans drawn out already for that.
Old 06-25-2005, 09:01 PM   #9
pedrofixlater
75 STEPSIDE
Thumbs up 6X9's
Here are the pics of the 6X9's, The sub box i built is 3" width on top and 5" width on the botom I made the boxes 18" wide by 12" tall and the whole box is 46" long. The back is all one piece.
Pete
75 Chevy Stepside
70 Buick Skylark/GS
Old 06-25-2005, 10:25 PM   #10
jermasaurus
I am using two seperate boxes for 12"s that were behind my bench seat, now one is between the backs of my seats, and the other laying on the floor in between them. I am interested in a setup like this http://www.decware.com/tbk10.htm or a center console incorporating the two subwoofers.
-Jeremy
Old 06-26-2005, 02:20 AM   #11
bodydropped
in my 78 im runnin 2 memphos 6x9s in the corners 4 12's behind the seat i had 2 6.5s in the kick panals but i still got the speakers but i got to cut my new kick panal but im fixin to make a console for 2 15's soon
bodydropped is offline   Reply With Quote
Old 06-26-2005, 12:27 PM   #12
jermasaurus
Got any pictures of the 4 12's in that box, I assume it is sealed. Can you get a decent amount of cubic feet with that setup? The thought of doing that crossed my mind. If I had 4, I could be down to 2 ohms per channel and be putting out more constant than with my 2 subs at 4 ohms per cahnnel.
-Jeremy
Old 06-27-2005, 01:10 AM   #13
bagged_and_bodydrop
Just drag it
[QUOTE=bodydropped] 4 12's behind the seat ]
Did you have to cut the back of the cab out and run your box into the bed for them? If you didn't then what kind of box do you have and how many Cubic feet is it, is it ported or sealed, how do you keep them from gettin to hot behind the seat period, what kind of amps are you running and where did you mount them, what kind of Subs are they, how many watts and ohms are they, and do you have them wired for 2 or 4 ohms? Lots of questions sorry, lol, but I'd love to get four 12s behind the seat, I got 2 Memphis M3s and they keep gettin hot along with the amps. Thanks. Again sorry for all the questions.
bagged_and_bodydrop is offline   Reply With Quote
Old 06-27-2005, 04:26 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I have 2 6x9s behing the seat and am planning to hook up a 12" Sub behind the seat too. I like the idea of the 6x9s in the door.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-27-2005, 10:15 AM   #15
86 GMG
I Believe The Kick Panels You Guys Are Speaking Of Are Cal (q Power) They Look Really Nice But They Stick Out To Far For My Liking But I Like A Lot Af Leg Room Also Me Personally Like Alittle Thump In The Truck But I Want To Be Able To Her My Kids Cuss Me When I'm Older So Maybe A 12 Sub And Good Sounding Midds And Highs Up Front
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 06-27-2005, 06:33 PM   #16
bodydropped
nope i didnt have to cut the cab out at all there in a sealed box the seats im runnin or 94 honda civic seats i had 2 12's behind my seat when i had a bench seat
i know there 2 different type but there the same subs but depth charge was replaced with street edge
the hole is there because i got bored and drilled a hole but its blocked off know
my console were my amp and line driver go under
amp a memphis 1000d that im runnin at 2 ohms
memphis line driver
and on the ? about gettin hott only time my subs get hott is if i beat teh crap out of them but mainly my cd plyaer stays at -1 for the subs and -6 for the high end and my amp is turned half way up but u probably wither under powerin ur subs or over powerin them or runnin them at to low of ohms but pm me with more info
Old 06-27-2005, 09:59 PM   #17
SSC's76
No No
SSC's76's Avatar
I'm not a huge fan of cutting the doors IMO it looks cheap. (No flames please it's my opinion do what you like it's your ride)
I have two MTX TS82 boxes behind the seat, two Audio Junk enclosures on the sides, a Pioneer 4x6 in the factory spot and a MTX tweeter hidden in an ac duct. Sounds good dident cost alot I just wish I would have gotten a different amp Sony sucks.
Sorry pics kinda big even with camera set to lowest res.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 06-27-2005, 10:27 PM   #18
texan1186
Under Major Construction
texan1186's Avatar
heres what i had a while back its two infinity tens and two fosgate 6x9's in a sealed box. and four 4" fosgates in the headliner. i had two 12" fosgates after the tens but the froze up due to the tiny box, so now i have nothing
texan1186 is offline   Reply With Quote
