Old 06-25-2005, 04:35 PM   #1
70GMCer
70GMCer's Avatar
Picture of Transmission Crossmember Please
I just finished removing the standard transmission crossmember and need to know if the auto crossmember goes back into the same mounting holes on the frame...........picture would be extra nice......thanks.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-25-2005, 05:46 PM   #2
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Further Back
I am ACTUALLY going the other way, TH400 out, SM465 in. The 4-speed XM is up on the curved part of the frame, where as the auto XM is back further on the flat part of the frame. I am out working on mine right now if you need any measurements. Let me know, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 06-25-2005, 06:04 PM   #3
70GMCer
70GMCer's Avatar
I did see where there are another set of bolt holes just back of the ones that the manual XM was. Is this where to bolt up the auto XM, or do you have to drill new holes?
Steve
1997 GMC Sierra Ext
1965 Mustang
Old 06-25-2005, 06:08 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
should be able to bolt in the xm no drilling need
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-25-2005, 06:29 PM   #5
Gee_Emm
There should be 2 sets of holes further back, one set is for the TH350 and one set is for the TH400
Gee_Emm is offline   Reply With Quote
Old 06-25-2005, 09:45 PM   #6
Randy70C-10
Randy70C-10's Avatar
I always have the best luck bolting the crossmember to the chassis with the tranny installed and on a jack, that way I know that I won't have to move it.
Randy70C-10 is offline   Reply With Quote
Old 06-25-2005, 10:36 PM   #7
longhorn71
longhorn71's Avatar
longhorn71 is offline   Reply With Quote
Old 06-26-2005, 07:13 AM   #8
70GMCer
70GMCer's Avatar
this might be asking for too much, but would anyone have a picture of the XM in place with the 350 turbo installed?
thanks for the help........
1997 GMC Sierra Ext
1965 Mustang
Old 06-26-2005, 07:41 AM   #9
hotrodmtodd
'Burban Legend
PM sent
Steve,
Check your PMs.
Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
Old 06-26-2005, 10:36 AM   #10
purple gas
if your using V-8 motor mounts the member goes farther back than the standard tranny holes, but not the holes farthest back ( if I remember correctly) . If you have small fingers and some knuckle skin to spare it's possible (barely) to set the member in the frame rails put the motor & tranny in place lines up the holes and bolt the member in when you get the holes lined up. BUT doing it that way you need fairly short bolts for the top portion. Or you can guess and bolt everything REAL tight only to find your a couple inches out & have to move it all later. That's what I did, but I don't recomend it.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 06-26-2005, 10:53 AM   #11
purple gas
If your motor & tranny are connected, measure from where the tranny bolts to the member ( 2 holes on bottom of tailshaft) to the place where the motor mount bolts are. Transfer that distance to the corrosponding places on the frame. Start with the motor mounts then slide ( or hammer it might be tight) the tranny x-member back till it's the right distance. The holes should line up.
Old 06-26-2005, 11:21 AM   #12
70GMCer
70GMCer's Avatar
that's what I needed to know.........thanks guys.........
1997 GMC Sierra Ext
1965 Mustang
