06-25-2005, 06:38 PM | #1 |
*Proud Member*
Ball joint Spinning... lowering job
Putting in a set of drop springs today and when putting my suspension back together, the lower ball joint spins a little when tightening the castle nut... should i reach for the impact? is this normal?
06-25-2005, 07:37 PM | #2 |
Usually when the BJ spins, it's a sign of wear. It should be replaced. The cost of a new ball joint can be far less than the damage caused by one that fails while driving down the road.
That being said . . ..... if you wish to continue, 'tap' on the spindle to try to seat the BJ stud a little more. That should grip the stud better & keep it from spinning.
06-25-2005, 10:06 PM | #3 |
No No
I'd replace it just to be safe. Ever see a ball joint fail? I'm sure that $30 for a new one would offset the cost of a tow and possible damage
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
06-25-2005, 10:19 PM | #4 |
If you must get it back together for now, use a C clamp to hold the spindel to the control arm.
-Jeremy |
06-26-2005, 03:44 AM | #5 |
i'm sorry, but that has to be the dumbest thing i have ever heard. suspension, especially on the steer end of the trucks is one of the 2 things that you should not compromise, no matter what the circumstances. the other being brakes.
06-26-2005, 11:08 AM | #6 |
*Proud Member*
what is the best way to pop the ball joints out?
06-26-2005, 11:39 AM | #7 | |
*Proud Member*
ya, i realize the press in and out... so, its probably easiest to just take the lower control arms totally off...??? |
06-26-2005, 02:32 PM | #8 | |
Pulling the arm off the truck might make things easier to work on, but it's not mandatory.
06-26-2005, 05:39 PM | #9 | |
Insert Witty Text Here
Slonaker |
