Just here to help
![]() Join Date: Jan 2002
Saddle tank help needed
Hey guys i am trying to take the saddle tank out of my 4x4 to take it to get it cleaned(haveing to change gas filters every 40 miles),i got the cab tank out but not sure how the saddle tank is mounted.I tried the three bolts on the bottom of the tank but nothing there.Also it is a wood bed if that makes a difference.Thanx....
#16876
If it is like mine there are two bolts the tank hangs from. You should see the heads in the wood part. Mine have oval shaped washers. They were a bear to remove because of years of debris accumulation in the holes for the bolts. On the bottom you should see two funny looking nuts with two holes in them. I sharpened a flat screw driver and used it and a hammer to turn them. You may want to jack the tank up slightly. When I was able the break them I used a ratched without a socket to turn them. Save the bolts, they cant be replaced. Make sure to drain all of the gas out, and disconnect the sending unit wires and fuel lines first.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
"Ochre Ogre"
Those are the ones holding the tank in there. You will be darn lucky to get them un-done. The only way to drop that tank with a Minnesota truck is to grind the heads off the bolts and let it drop. After doing that you will usually find that the top of the tank has rusted through.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Just here to help
I dont have anything that looks like those on mine,I have three bolts on the bottom of my tank,Is mine different than most?
ours looked like the above pic.Once the floor rotted they just fell out
#6 | |
#16876
![]() Join Date: Mar 2003
A few of the tanks I have pulled out I have had to weld a 1/2'' nut to the flange because the 1/2'' hole rounded out while trying to unscrew the anchors.
