Old 06-26-2005, 12:57 AM   #1
unixadm
WTB: 72 Truck 4x4 parts and more....
I'm in need of the following parts for my 72 C20. It was converted to 4wd and is missing certain things. I also want to put a lift on, so if anyone has one that is in good condition let me know.
1. Front swaybar frame mounting brackets for a DANA 44HD
2. Front shock mounts (small angled brackets) and bolts
3. Small block fan shroud, shallow. Not the deep one normally seen on 4x4's.
3. Front 4x4 SBC Engine Cross-member
4. 4 speed shift boot and retaining ring
5. NP205 Transfer Case shift boot and retaining ring
6. Black Carpet Kit for Tall Hump
7. 2-4" Spring Lift (front and rear springs) and shocks
I prefer to pay with Paypal if possible. PM me with any details.
Thank you!
- '72 Chevy C20 4x4 LWB Fleetside, 350/SM465, NP205, '73+ Axles (D44/14B FF 8-lug), 4 Wheel Discs - Updated Pics
unixadm is offline   Reply With Quote
Old 06-26-2005, 10:37 AM   #2
Burnsman
Chevy Freak
Burnsman's Avatar
parts
I have the 4x4 sbc xmember, front shock mounts, and the front sway bar off of a 73-77 with fabbed mounts (since no 67-72 4x4's came originally w/ the front sway bar). xmember and shock mounts would be $80 to your door. Sway bar w/ mounts would be another $50. I can get pics if you need them. Just let me know. Thanks. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 06-26-2005, 11:11 AM   #3
unixadm
Brian,
Pics would be great. I'm very interested! I appreciate for the info about the swaybar - I didn't know that.
Thanks,
David
Old 06-26-2005, 03:14 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
Burnsman, if unixadm passes on the swaybar, I may be interested. Please PM me if my number comes up.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-26-2005, 04:53 PM   #5
Burnsman
Chevy Freak
Burnsman's Avatar
parts
Here are pics of the shock mounts (I assume this is what you want?), the front engine crossmember, and the sway bar (shown upside down). I will cut it in front of the crossmember to save the front frame horns (and save weight on shipping). You can see that the guy welded them to the middle crossmember. You can either swap the crossmemebr out or grind the welds and re-weld them to yours. I was going to try to fab some different brackets so that I could unbolt it. Just let me know if you need any of it. Thanks. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 06-27-2005, 04:00 PM   #6
unixadm
So is it $130 for everything shipped? Do the shocks mounts come with the thru-bolts and nuts? Do you take paypal?
Thanks!
David
Old 06-27-2005, 04:21 PM   #7
Burnsman
Chevy Freak
Burnsman's Avatar
parts
David, correct. It would be $130 for everything shipped. I can save the bolts for the shocks. It would take me a few days to get everything off and boxed. I'll PM you payment info if interested. Thanks. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
