Old 06-26-2005, 03:04 PM   #1
KEH
Better late than never
KEH's Avatar
4 core radiator installation
I ordered a 4 core radiator from radiator.com. I am going from a 3 row and someone had said on another thread that new mounts are required with a 4 core. Radiator.com said that it is an OEM install.
Will I need new brackets? If so, I guess vendors will have them or do I have to go to the parts yard?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-26-2005, 03:13 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have also heard new mounts are needed, but last year I installed a new 4-row using the oem mounts.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-26-2005, 03:30 PM   #3
KEH
KEH's Avatar
Cool, thanks Stocker.
Old 06-26-2005, 06:13 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You need new retainers & pads for the top & bottom. All the vendors should have them. Your local chevy dealership should too. They are just slightly longer than the 3 core brakets and not very expensive. I replaced the 3 core in my '69 Blazer with a 4 core.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-26-2005, 07:09 PM   #5
71RestoRod
71RestoRod's Avatar
You will also most likely have to modify your radiator support as well. No big deal, you just bend down the lip on the support so the longer bottom 4-core retainers can bolt down flush to the support.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 06-26-2005, 07:31 PM   #6
71Dragtruck
71Dragtruck's Avatar
When I went from a 3 to a 4 in my 71 GMC 2wd it bolted right in without changing a thing.
71Dragtruck is offline   Reply With Quote
Old 06-26-2005, 08:16 PM   #7
krue
Designated A-hole!
krue's Avatar
It may depend on how worn your radiator mounts are.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-26-2005, 09:03 PM   #8
dwaite72lnghrn
If you have a 3 core now all you need todo is put in new rubber mounts as long as the bottom mounts are not rusted off. The old 3 core rubber will probable work but the new rubber will give a better cusion. I just put a 4 core from GMC pauls in.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
