06-26-2005, 08:00 PM | #1 |
Another tire size question
I'v decided to go with the BFG's Radial T/A 275/60/15 on my 86 SB, but I was thinking of going a little smaller in the front and was wondering if you guys had an opinion of what might look good in the front? Maybe a 255/60? or would this look to short? Or 235/70 (same diameter as the 275/60) Or should I go the same on all 4 corners? These are going on 8" Ralleys on a standard stance short bed.
Thanks for any opinions Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week. Last edited by red86chevy; 06-26-2005 at 08:39 PM. |
06-26-2005, 09:35 PM | #2 |
Web Wheeler
IMO, taller meats on the back looks good if you can keep the truck level... otherwise it looks redneck (but that can be okay too )
At one point I ran 225/60R16 on the front and 265/75R16 on the back. The rake was so pronounced it effectively increased my caster angle and made it turn sharper.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
06-26-2005, 11:06 PM | #3 |
needin' money
go with 235/60/15's on the front, it will give you a 2 inch rake
06-26-2005, 11:28 PM | #4 |
I like the same all the way around. It looks good, and you can rotate your tires.
Real Name - Brandon Current Vehicles: 1977 C20 Silverado 454/TH400 3.73s 1989 Jaguar XJ6 in the middle of an LT1/4L60E swap |
06-27-2005, 08:38 AM | #5 |
I am running BF Goodrich Radial T/A P245/60/15 on the front and P275/60/15 on the rear.
06-27-2005, 11:04 PM | #6 |
Ive got 275/60s on rear 225/70s on front
75 GMC C-15 short/step factory 454, lowered |
