What is a good price on a 5 lug 12 bolt out from under a '78? I purchased one from my buddy with drums and all for $75. It seems to have about a 3.40 gear in it (by turning and counting) but I have not counted the # of teeth to see exactly what the ratio is. I figured when I tear up my 10 bolt under my '86 I'll rebuild the 12 bolt with new bearings, seals, 3.73 gear and posi. He had the old truck (wrecked) and I could not resist not getting the rear out from under it before it got junked. Maybe I didn't get jipped?
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week. |
#2 | |
Most likely 3.42. If it is what you want, isn't broken or worn out, you can use it, you can afford it, sounds like you saved money, then it is a good deal. Plus you saved American Iron and recycled it to your truck.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
Be sure you allow for changing the drive shaft. Using a 12-bolt requires a shaft about 3/4" longer than the same truck with a 10-bolt.
Born a Chevy Man
Did most of our trucks come with a ten bolt? My '86 is a ten bolt but the '70 was a twelve bolt?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#5 | |
Insert Witty Text Here
Slonaker |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
There was an overlap. There can be 1981 10bolt and 1982 12bolts. GM used up stock until they were gone.
(For the 73-87s) 12bolts were 1973 - 1981 10bolts were 1981 - 1987
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
