Old 06-27-2005, 12:47 AM   #1
squizzleboy
Floor Pans???
I have a 63 chevy longbed. I have some rust in the floor pans but dont know what to do with it. Should i replace the section, paint over it w/ POR-15 or what??? All the help i can get is appreciated
squizzleboy is offline   Reply With Quote
Old 06-27-2005, 01:01 AM   #2
squizzleboy
sorry, heres the pics
Old 06-27-2005, 03:39 PM   #3
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Talking Rust is not going away soon
Depends on what you are wanting for your truck? Daily driver? Or Complete restoration? Depends on you? Looks like from the photos you would want to replace the floor pan sections sometime soon. As that rust is pretty bad from what I can see.
my 2 cents worth rico_bob
Rico's Rods & Relics ~ "Treasure the Ride in Pride"
www.ricos-rods-and-relics.com
Classic Trucks and Muscle Cars
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 06-27-2005, 08:08 PM   #4
D Knaub
D Knaub's Avatar
What does the underside look like? Are the cab supports rotted? If so, plan on replacing the supports, and splice in some new pans.
If the supports are good, you could treat the pan with a metal conditioner, then coat with por 15, and cover with a metal plate pop-riveted over it to pass inspection.
Dave.
D Knaub is offline   Reply With Quote
Old 06-28-2005, 02:09 AM   #5
squizzleboy
It will be a daily driver. The bottom is pretty much the same. DO i have to weld it or can i rivet or screw it in(i know it the cheap way but...) I have an oxy/acet torch that i have never used. Would that be to hard for a beginer? I have used a mig to weld pipeing together for a while but sheetmetal is different, right. Thanks.
Old 06-28-2005, 08:50 AM   #6
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Use the mig and set the heat and speed accordingly per your chart. Be careful with that Oxy/Acet torch near gas and grease. Never NEVER cut or weld near grease it is explosive. My 2-cents worth rico_bob
