Vent Window Rebuild?s
Can someone run through the procedure for putting new weatherstipping (seal) on the vent windows? Thanks, Brandon
btt
Street Rod Restoration
![]() Join Date: Jan 2004
hmmm...
i think you want to ask board member 75stepside
Follow me on Instagram @ hot_rod_shop |
*Proud Member*
did someone call me up! ya, i've done two sets... check my this page on my site: http://merlin2.alleg.edu/student/t/t...rogress19.html
basically, after the frames are out, just grind off the two rivets on the frame that hold the hinge part on... and that will allow you to pull the glass out of the frame... get out a good set of plyers and yank out the old seal... sandblast, paint, install new seal, and put hinge back together - i used two 5mm bolts instead of the factory rivets. ![]() ![]() ![]() |
