Old 06-27-2005, 10:22 AM   #1
TWOKEELYA
TWOKEELYA's Avatar
Transfer case /old faithful
My 2.5 year old son and I took the 68 for a ride to the scale so I can get it regestered, 4800 lbs. On the wy back, smoke filled the cab, I pulled over and couldn't believe my eyes. The transfer case had blown all the gear oil straight up and it was pouring down from the crossmember and everything under was covered. What would cause this? could this just be a seal or Am I in deep.
Richard
Not all who wander are lost
TWOKEELYA is offline   Reply With Quote
Old 06-27-2005, 10:38 AM   #2
chevyfarmer
chevyfarmer's Avatar
Is it coming out the breather on the top of the t case? Is is a auto or manual tranny? I had a 72 4x4 blazer that did the same thing, the seal between the tranny and t case was wasted so it filled the t case with tranny fluid.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 06-27-2005, 11:45 AM   #3
TWOKEELYA
TWOKEELYA's Avatar
It is a auto, the trans fluid level is ok, and the fluid is black gear oil.
Old 06-27-2005, 12:03 PM   #4
wolfthing2000
Is this the Rockwell transfercase????
wolfthing2000 is offline   Reply With Quote
Old 06-27-2005, 12:07 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Is it a rockwell T221? Was the case hot when it happened? I'd guess it is time for some new seals. While you have it open, you can see if it has any debris in the case.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-27-2005, 12:13 PM   #6
TWOKEELYA
TWOKEELYA's Avatar
I'm Not Sure, I'll Check Tonight. Would Driving It In 4 Wheel At High Speed Cause This?
Old 06-27-2005, 12:58 PM   #7
Ray_71Chev_in_PA
Ray_71Chev_in_PA's Avatar
Richard,
You had the truck in 4WD on the pavement?
Ray
1971 C10/350/Blue/White/Blue in Boyertown, PA
Ray_71Chev_in_PA is offline   Reply With Quote
Old 06-27-2005, 01:10 PM   #8
TWOKEELYA
TWOKEELYA's Avatar
Originally Posted by Ray_71Chev_in_PA
Richard,
Ray
No, but I wonder if the P.O. or the transport company had put it in 4 to load, and when they unloaded and drove it here in 4wd. This was my first long drive when it erupted, the only other time I've driven it is around the block.
Old 06-27-2005, 01:15 PM   #9
Ray_71Chev_in_PA
Richard,
I'd be concerned as well. You'd know right away if it was in 4WD while you were driving it. As for previous drivers, no telling. I read your post because I have an Early Bronco than smokes from oil from the transmission/transfer case area as well. It'll get your attention!
Ray
Old 06-27-2005, 01:30 PM   #10
TWOKEELYA
TWOKEELYA's Avatar
Ray,
This thing just blew like a geyser, everything out. I could see under the tunnel where the shifter is that it had blown upward. May even be out of the shifter hole, I can’t tell yet. Also, when I was stopped along the roadside, it was pouring off the cross member and drenching the ground, big puddles! I never knew there could be so much oil in the transfer case. How much do they hold anyway?
Old 06-27-2005, 02:31 PM   #11
Ray_71Chev_in_PA
Richard,
Not sure how much it holds. My truck is 2WD! The manual I have says "...add oil as required" which means it has a fill hole. You add lube until it won't take anymore.
Ray
Old 06-28-2005, 11:56 AM   #12
1969 GMC
1969 GMC's Avatar
If the truck is an auto, which has been swapped in from a later model, I am willing to bet it also has a newer t-case (NP205 most likely).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-28-2005, 10:09 PM   #13
tedfrk
tedfrk's Avatar
if it is an np 203 use sae 10 w 30 or 10 w 40 motor oil the last time i had it changed they were going to use gear oil i am just glad i was there
tedfrk is offline   Reply With Quote
