Old 06-27-2005, 12:55 PM   #1
Richard Dobson
Bumper Brackets?
Can anyone tell me (or show Pictures) of the difference between the 67-68 & 69-72 bumper brackets. I'm putting a 68 clip on my 71 and according to the catalogs they're different but it's hard to tell the difference in the cat's. Thanks
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 06-27-2005, 03:53 PM   #2
JimKshortstep4x4
Talking
I can post a pic if you let me know if you are working with a C-10 or K-10 as it makes a difference.
The 71-72 front bumper brackets are different from the other years because of the lights in the bumper.
Jim
Old 06-27-2005, 04:32 PM   #3
Richard Dobson
Thanks JimKshortstep for your reply. My 71 Chevy is a C10 fleetside onto which I am pitting a 68 front clip. Like you say the turn signal lights are in the grill on the 68 vs in the bumper on the 71. When I bought the 68 clip I didn't realize the bumper bracket issue would creep up. Since I have already bought the 67-68 bumper I am going to need the proper brackets. Thanks for the info. Regards
Richard Dobson
Old 06-27-2005, 04:37 PM   #4
72MARIO
72MARIO's Avatar
Yes. You need 67-70 bumper brackets if you want to use a 67-70 bumper. I went thru the same problem. You may also need to notch the drivers side to clear the powes steering box.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-27-2005, 04:51 PM   #5
70c10
67-72 Addict!
70c10's Avatar
I would not recommend buying used brackets just in case that was your plan. Buy new ones from a BOARD VENDOR!. There is no way to tell if the bumper was ever tapped in it's 30+ years causing a slight bend. This will drive you crazy when hanging the bumper because you might not realize which of the 4 is bent. I went thru this back in the fall.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-27-2005, 05:00 PM   #6
longhorn71
longhorn71's Avatar
longhorn71 is offline   Reply With Quote
Old 06-27-2005, 05:06 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I also
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-27-2005, 06:52 PM   #8
speedracer
Blank
speedracer's Avatar
I'm third on the agreeing!!!
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 06-28-2005, 12:43 PM   #9
Richard Dobson
Thanks guys, Sorry I'm late one replying to you. I had an accident yesterday going home from work. A Honda pulled in front of me and both cars are totaled, I was't hurt but the couple in the other care were injured. The bad part other than the injuries is that they don't have insurance. So my little mide size truck that I haul all my parts from swap meets, body shops etc is toast and I will have to replace it. Don't get used brackets eh? Thanks for the advice. How do the uninsured keep on the road? Hell, if I didn't have proof of insurance at this wreck I would have been stripped searched.
Richard Dobson
Old 06-28-2005, 02:59 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Here in Maryland we are protected by the UNINSURED MOTORIST FUND. We all pay into it. Check with your agent.
Jim
Old 06-28-2005, 04:03 PM   #11
Richard Dobson
I'm hoping as a last restort (if I can't find any before then) that in the fall at the Charlotte Auto Fair to be able to find a set of org ones from all the aviable resourses there. So if anyone could I would appreciate it if you could make digital shots of 67-68 brackets. I have found everything orginal but a front bed panel and a tailgate so far, my experience with aftermarket vs org hasn't exactly enjoyable. Thanks for all your advise & input.
Richard Dobson
Old 06-28-2005, 05:11 PM   #12
72MARIO
72MARIO's Avatar
Richard.
I would reccomend MAR-K front bed pannels. I am a perfectionest and I have had nothing but problems with new Repo non GM parts. The headboard fit without dremmling anyholes PERFECT. I was amazed at how well it fit. It awesome .Ity came in a 1"x3" wood crate to protect the edges.y not to be a put down but you will never find a old front pannels thats not full of dents. I looked for 3 years untill I broke down and bought the MAR-K one
2005 TAHOE DD
