06-27-2005, 01:15 PM | #1 |
hydrobooster leak help
Hi guys,
It seems my hydrobooster is leaking power steering fluid. I tried to find the search function on the board to no avail. Could someone please tell me what my options are? Are there o-rings/seals etc. that can leak, or does this normally require replacing the hydrobooster unit? Do you guys have the procedure documented somewhere? Do I have to break open the brake system...needing to bleed the ABS unit and brake lines? 1994 K2500 Suburban Thanks for your help. Tom |
06-27-2005, 10:08 PM | #2 |
My '86 CC Dually did the same thing.
Go to the local GM dealer and get a hydroboost rebuild kit. It was cheap and easy to do, you don't get into the brake system itself at all. Really simple Just seals and O rings and I believe it had directions too. Just my .02 CCDually Last edited by GMC1tondually4dr; 06-27-2005 at 10:12 PM. |
06-28-2005, 10:31 AM | #3 |
thanks for the tip. order of magnitude difference in price.
06-29-2005, 09:24 AM | #4 |
Chevy Forever
Not to hijack this thread but I was looking into purchasing a hydro booster from the junk yard in town they told me they would take 35 bucks for it. All I need to know is this a good price plus is there anything I need to look out for when checking it out. Thank you for your help
06-29-2005, 12:06 PM | #5 |
........Yep....sounds good.
Look for cracks, shouldn't be any. (No way to crack with normal use.) Go get a rebuild kit, you then have years of trouble free use. Look on www.car-part.com Check the prices on that site, in your area. Sometimes on Ebay $30 to $50 Just my .02 CCDually Last edited by GMC1tondually4dr; 06-29-2005 at 12:10 PM. |
