Old 06-27-2005, 04:48 PM   #1
landarts
landarts
c20 custom deluxe "71"
I found a c-20 custom deluxe suburban today sitting on the street for sale- the body has no dents with slight rust on drivers side rear lip of the fender, all glass is good. the motor is a 396 , automatic with a/cc to the rear only, the dash had the factory tach , however there are no ac vents on the dash ??? front and second row searts stock, headliner good. 8 lug rims , stock bumpers and grill.
The guy is asking $ 2500 ....I will try to get some pictures and vin numbers. what do you think ? Jim
landarts is offline   Reply With Quote
Old 06-27-2005, 05:02 PM   #2
Hart_Rod
Hart_Rod's Avatar
Sounds good! Send pics.
r
Hart_Rod is offline   Reply With Quote
Old 06-27-2005, 07:24 PM   #3
Long Roof
Old School, New Style
Long Roof's Avatar
Pics if you can get them. Where are you from?
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 06-27-2005, 07:29 PM   #4
Long Roof
Long Roof's Avatar
I think you can get them most every truck parts supplier. They all sell the same kind if it is a good kit. ACC is the carpet co. Check out www.GMCpauls.com or www.mothertruckers.net I think they bother carry them.
Aaron
(Never mind the jibberish above, it belongs somewhere else)
The Good:
The Bad:
The Ugly:
Old 06-28-2005, 01:09 AM   #5
4x4Poet
Originally Posted by Long Roof
I think you can get them most every truck parts supplier. They all sell the same kind if it is a good kit. ACC is the carpet co. Check out www.GMCpauls.com or www.mothertruckers.net I think they bother carry them....
Long Roof, he was talking only about the A/C, meaning the air cond system.
LandArts, did the roof air have a channel along the roof back to the rear unit? Maybe it had an underdash unit once. Sounds like it has good potential, especially if the 396 is stock. Check the glove box sticker to see if the engine is original. Most likely, it is, since most 396s were taken out, vice put in. And could you more specifically describe the area that has rust? Have you checked the front floors, cab supports, kick panels, and the rocker's door rubber lip for rust? The floor mats/carpet often hides much.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-28-2005, 07:04 PM   #6
Long Roof
Long Roof's Avatar
I have no clue how this post got on this thread. This post is supposed to go on the 'New pics of the burban' thread. I will move it over.
Aaron
The Good:
The Bad:
The Ugly:
Old 06-29-2005, 03:06 AM   #7
4x4Poet
LR, I just saw it over there. Makes more sense there.
Good advice, either place, though.
Old 06-29-2005, 06:18 PM   #8
Scrubby
Check out GMTrucks.org
The reason it has no A/C vents in the dash is because in '71 you could get the "roof a/c". It has the blower in the back, with the tunnel that runs all the way to the front. My 71 has the same thing, and it works fairly good except you have that big tunnel down the whole roof. If you have access to a 1971 owners manual, you can read about it.
This burb sounds just like mine. 1971 C-20 custom deluxe, 402, A/C, tach dash...
Scrubby is offline   Reply With Quote
Old 06-30-2005, 02:55 AM   #9
4x4Poet
Right, 402, not 396. Important when checking the glove box sticker.
