06-27-2005, 10:06 PM | #1 |
Out draggin'
73+ drop spindles on a 71/2???
What do I have to do to put a set of 73-87 C10 dropped spindles(1 1/4" rotors) on a 71/2 C10? Does it change the track width? Is it a direct swap or do I need to get diff. balljoints or control arms? How about tierod ends? Anything else?
Thanks! Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
06-28-2005, 12:10 PM | #2 |
Swap the upper ball joints, & the outer tierod ends, & the 73 up spindles will fit the 71/72. As far as track width......I dont think there is any difference, but not sure on that one. I do have 75 spindles on my 69, & dont see any problems........... L
http://community.webshots.com/user/hotrodhorn |
06-28-2005, 01:44 PM | #3 |
The only difference in track width should be when swapping from drums to discs. You'll gain approx 1/2" per side. If it's already discs, there won't be a change unless the manufacturer of certain spindles states this info.
06-28-2005, 04:57 PM | #4 |
You need a adapter sleve for the 73 tie rods. 67-70 outer on the inside and 73 outers.CPP sells the adapter sleve you need. Thats what I am using om the 67.
Mabye try using a center link from a 73n up truck if you dont want to shell out the money to CPP.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-28-2005, 06:01 PM | #5 | |
Seņor Member
06-29-2005, 08:05 AM | #6 | |
WTB this ad
06-29-2005, 04:35 PM | #7 |
Out draggin'
Price my brotha, price...
