Old 06-27-2005, 11:02 PM   #1
CHEVYE
my gas saver
CHEVYE's Avatar
? about roll pan
this might be a dumb one but i was trial fitting my roll pan tonight and it appears i have to notch out the bed to fit the lisc. plate box. just wanted to know if that sounds familiar to anyone before i get to hackin. it is a sir michael's if that makes a diff.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 06-27-2005, 11:14 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I didn't have to notch mine. My roll pan is a Mar-k product though.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-27-2005, 11:24 PM   #3
CHEVYE
my gas saver
CHEVYE's Avatar
here's where it hits. the pan doesn't drop in the middle near the plate, it stays the same all the way across.
71`SWB, project
ebay feedback
Old 06-28-2005, 05:45 AM   #4
gchemist
gchemist's Avatar
That roll pan has one big plate box. Looks like you will have to notch the bed rail.
Old 06-28-2005, 03:46 PM   #5
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
i dont quite get that pic.....it appears the platebox is behind the pan itself??, and why is it so deep? at any rate, if the second pic is taken witht he rollpan at the same height as your first pic that could be your problem. that pan needs to be up farther another 2" or so so that your body line lines up. that will pull the pan out farther and probably allow your plate box to sit flush against that rail. hope this helps.
milehightoyz is offline   Reply With Quote
Old 06-28-2005, 04:22 PM   #6
CHEVYE
my gas saver
CHEVYE's Avatar
i just quick clamped it where it stopped itself. i don't know why it's so deep. now i'm debating even welding it up . i might try to get the kind "bigarmzz" has that slants down in the middle.
71`SWB, project
ebay feedback
Old 06-28-2005, 04:27 PM   #7
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
roll pan
I had to cut out my rear cross but mine is a stepside I got mine from
mar-k.com
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 06-28-2005, 04:30 PM   #8
82c10
needin' money
see if you can slide it in from the top somehow, if it won't take where the plate box goes on and make it recess in the rollpan less, just some ideas
82c10 is offline   Reply With Quote
Old 06-28-2005, 04:43 PM   #9
75stepside
*Proud Member*
75stepside's Avatar
mar-k.com
same here... got my stepside pan from www.mar-k.com ...do you have a pic of yours on?
75stepside is offline   Reply With Quote
Old 06-28-2005, 04:56 PM   #10
CHEVYE
my gas saver
CHEVYE's Avatar
it won't go anyway i try it. looks like it's time to cut either the bed or the plate box on the pan .
71`SWB, project
ebay feedback
Old 06-28-2005, 05:23 PM   #11
milehightoyz
if you decide not to use it ill buy it i need it for my 82 shortwide =)
Old 06-28-2005, 11:31 PM   #12
84slopwaggin
84slopwaggin's Avatar
Maybe it's just the wrong year roll pan.
84slopwaggin is offline   Reply With Quote
Old 06-29-2005, 01:15 AM   #13
bagged_and_bodydrop
Just drag it
I cut the part out of the bed on mine, and mine is a Mark-K no big deal to cut it, and mine lines up pefectly after I cut that piece out. So I'd say cut away. Just not to much.
bagged_and_bodydrop is offline   Reply With Quote
