06-28-2005, 12:02 AM | #1 |
Another bag ??
I've decided to start the front of the suspension today(I was bored).
If I don't get the back done is it bad to drive with just the front? This is more then likely a stupid question but i have to ask. I want to get it all done before I drive it but I might not get to. Will it screw up the pinion angle if I was to drive it higher then the 6 inch drop the front had? Secondly, does anyone know a good bolt in 4 link kit and where to buy it from? I would really like to a weld in one but there's no one in abilene that can do it and the guy I was going to borrow a trailer from to take to DFW, sold his trailer. Thanks for any help ya'll can give
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
06-28-2005, 08:12 AM | #2 |
I've been driving with just the rear done for 3 weeks. FATMAN Fabrication might make one or Heidts.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-28-2005, 09:16 AM | #3 |
It won't hurt to do just the front as long as the drop isn't too exaggerated. As for the bolt-on 4-link, that's going to be tough. I know KP components has a bolt on kit for the 73-up trucks. Maybe it could be tweaked to fit a 67-72 w/leafs.
Have you considered an air-over-leaf set-up? N2TRUX uses one on his 77 w/o any issues & it rides nice. I wouldn't go that route on high HP applications, but for normal use it works fine. Check AirRides site for details.
06-28-2005, 10:49 AM | #4 |
I pm'd N2TRUX, to ask about his set-up. It looks like thats the only way I can go for now. thanks for the info
