Old 06-28-2005, 04:14 AM   #1
mrwilmoth
anyone that fabricates
I need a stereo cover plate that fits in flush into where the factory stereo goes, it needs to be flush with the dash and attached by two screws. can someone do this for me? thanks
btw my current dash is cut so I cannot use a regular radio delete plate.
mrwilmoth is offline   Reply With Quote
Old 06-28-2005, 09:23 AM   #2
Putter
More Cowbell....
Putter's Avatar
SO, in so many words, you need an OVERSIZED radio delete? Can you sketch it out for me?? Do you want it flush with the recessed part....or flush with the non-recessed part (like the remainder of the dash)????
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-28-2005, 02:55 PM   #3
mrwilmoth
flush like the remainder of the dash.
Old 06-28-2005, 04:35 PM   #4
Putter
More Cowbell....
Putter's Avatar
So, are you wanting to delete it....or be able to install a radio? I have an uncut center section if you need it from a donor dash....or, I can make a delete with the raised rib around it (so it looks almost like a stock piece) that will sit on the 'remainder' section of the dash, fasten from the back, and be slightly larger than the recess.
Old 06-28-2005, 07:07 PM   #5
mrwilmoth
ya thats what I want. something that covers it and looks like the factory. thanks alot
>or, I can make a delete with the raised rib around it (so it looks almost like a >stock piece) that will sit on the 'remainder' section of the dash, fasten from the >back, and be slightly larger than the recess.
Old 06-29-2005, 11:04 AM   #6
Putter
More Cowbell....
Putter's Avatar
Any chance in the world that you can get a picture of your dash, so I can SEE how much is actually cut out & guesstimate where the fasteners should be???
