Old 06-28-2005, 04:20 AM   #1
mrwilmoth
Wtb: Automatic Column W/ Overdrive
I want a rebuilt automatic column for my 67 gmc swb. It needs to be setup for a overdrive trans (700r4). I currently have a lokar floor shifter (2 months old, but was not installed by me, the previous owner put it in) and would like to put it back original. let me know
mrwilmoth is offline   Reply With Quote
Old 07-01-2005, 03:17 AM   #2
mrwilmoth
still looking
Old 07-01-2005, 03:28 AM   #3
longhorn71
longhorn71's Avatar
you could use a 3 speed auto column but you would not be able to manually shift it in to first gear
longhorn71 is offline   Reply With Quote
Old 07-01-2005, 06:55 AM   #4
Huck
Huck's Avatar
Here tell you can use a tilt which doesn't have the detent stuff on the bottom. You rely on the transmission detents. You can buy the 700R4 indicator from board venders.
Huck is offline   Reply With Quote
Old 07-01-2005, 09:11 AM   #5
Putter
More Cowbell....
Putter's Avatar
My tilt does not have the detents at the bottom, but it DOES have the detents inside it. The shift lever has a tab on it. I tested it before I installed it and it stopped at each position.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-01-2005, 11:36 AM   #6
sakohntr
sakohntr's Avatar
column
Why not use an early 90's van column with overdrive indicator???
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 07-01-2005, 11:41 AM   #7
bagged91
Out draggin'
bagged91's Avatar
Ignition switch is on the column for the 82/3 & up vans... He wants to retain the original appearance...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 07-02-2005, 03:58 AM   #8
mrwilmoth
ya I want something original.
when I find one I will have a very low used ididit tilt column and a lokar overdrive floorshifter forsale.
this is the look im going for:
Old 07-02-2005, 08:28 AM   #9
Is your column steel(painted),chrome,Aluminum,or Polished aluminum?I would be interested in that package for a custom.
Old 07-02-2005, 11:37 PM   #10
Bob Moore
OD Tilt
I modified my tilt by removing the nonOD gate(thats what I call it) that has the detents and installed a OD gate from a GM column with the OD detents. Use the shift lever from the OD column and you are home free. I usually look for late 70/early 80 full size Buick/Pontiac/Chevrolet cars as they have a more normal looking shift lever - The vans and Caddys have wierd bends in the lever.
This requires you to dismantle the column to get to the detent gate - almost completely. I also notched the outer housing to allow the shift arm to move a little bit further.
I am concerned about the pointer traveling beyond the indicator edges and snapping off but that happens with non modified columns unless your linkage is just right.
PM me if you are interested in more details - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-03-2005, 07:31 AM   #11
mrwilmoth
my current column is black paintable steel. and the lokar shifter is chome with a brushed alum. shift knob.
bob, could you make one for me like that
Old 07-07-2005, 02:28 AM   #12
mrwilmoth
still looking
Old 07-07-2005, 06:39 AM   #13
Hart_Rod
Hart_Rod's Avatar
Does column need to be tilt?
R
Hart_Rod is offline   Reply With Quote
Old 07-07-2005, 12:37 PM   #14
Bob Moore
Non-Tilt???
Hart Rob - I don't know for sure but the tilt columns have a detent gate while the non-tilt have the detent at the end of the column. You could probably grind the stop away to get more movement but I am not positive.
Anybody else have any thoughts?
vac, 454, T400
more to follow
Old 07-07-2005, 12:51 PM   #15
lvscott
how much are you going to ask for you ididit tilt column? i may be interested
thanks-brandon
lvscott is offline   Reply With Quote
Old 07-07-2005, 05:16 PM   #16
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
pm sent
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 07-08-2005, 03:27 AM   #17
mrwilmoth
it is a lokar floor shift automatic shifter with a chrome shaft and a brushed aluminum shift knob on it. it looks almost identical to a manual shifter. It was bought for about $200 or so, so I will let it go for less when I find my stock shifter
Old 07-08-2005, 07:36 AM   #18
Are you going to adapt an original column since you can`t buy one?Did you check Ididit to see if they make them for O/D?I bet they do.
Old 07-08-2005, 03:00 PM   #19
mrwilmoth
ya I emailed them and they should reply soon, then I will probally pick one up and sell the ones I have.
Old 07-08-2005, 03:19 PM   #20
lvscott
so is the ididit column a floor shift style with no shifter on it? if it is i'll take your old column.
Old 07-08-2005, 09:27 PM   #21
I had offered first.But,go for it.I`m not ready to use it.I`ll just buy a new one,
Old 07-08-2005, 11:08 PM   #22
lvscott
sorry special-k, i didnt notice your interest that you posted. not trying to step on any toes here. just was looking for the same thing i guess.
Old 07-09-2005, 06:09 AM   #23
That`s cool.I am nowhere near finishing touches on my shortbed.Always gathering for the future.He wants to sell the Lokar floor-shifter,too.I offered to take that,too.But, I really want to hold-out for an M22.
Old 07-09-2005, 11:02 PM   #24
dmec
dmec's Avatar
i make them from van columns, and i am in san bernadino
dmec is offline   Reply With Quote
Old 07-10-2005, 03:02 PM   #25
Jginger
Smile
dmec, how much for one of your columns?
p.s. I curently am running a 200r4 with a automatic column and using a lokar
linkage kit, I just ajusted trans arm where I have all 4 gears availabel on column, only problem is the shift pointer does`nt quite line up with indicater.
Jginger is offline   Reply With Quote
