Old 06-28-2005, 09:04 AM   #1
Maple Leaf C1O
5 Stud Front Brake Drum Swap 67-70
Has anyone ever had any success putting 5 stud brake drums on the front of a 67-70 truck as a bolt on from something else? I've looked for anything that uses the 11"x2" shoes and the same bearings, but no luck so far. Maybe something else with a complete backing plate, brake assembly, hub and drum will fit. The reason why I'm asking is I have found a complete set of 5 hole Rally Wheels cheap and I've already replaced the steel hard lines, shoes, hoses, cylinders, etc. I don't really want to put in a complete disc setup from a 71-72 unless I absolutely have to and would like to keep what I have changed already if possible. Axles, or a complete rear end assembly is not a problem to find to swap over the back end.
Maple Leaf C1O is offline   Reply With Quote
Old 06-28-2005, 09:19 AM   #2
Putter
More Cowbell....
Putter's Avatar
Have you looked at 73-80s? Thhe entire crossmember will bolt right up. I think you have to drill one hole for each side that doesn't quite match, but everything else is a GO!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-28-2005, 11:46 AM   #3
Maple Leaf C1O
I was hoping to find something that would work from the spindles outward so I wouldn't have to undo most of what I've already done. I have not checked the overall width of that type of crossmember, but now I will.
Old 06-28-2005, 03:10 PM   #4
crazy4chevs
crazy4chevs's Avatar
I'm not sure but I think you can have the front drums/hubs re drilled to five lug.
Anyone know for sure???
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
