Old 06-28-2005, 12:08 PM   #1
Nightrider
Nightrider's Avatar
No bright lights
OK Guys, I know this must be simple,but in 100 degree heat and a hangover I just can't get it. Lights turn on. When I hit the bright switch 'I replaced' the lights turn off. Checked all fuses.Some punk broke into it last week and stole the radio ,since then it seems to have a few probs! thanks
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 06-28-2005, 12:58 PM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Check your dimmer switch. I know for at least a week or two before I took my truck off the road, when I hit the dimmer switch my lights would go from bright to none. Replaced the dimmer switch, problem solved......... Hope it's that easy for you........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-28-2005, 01:08 PM   #3
mrein3
mrein3's Avatar
Check the connections at the dimmer switch (bright switch as you call it) for corroded connections.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-28-2005, 01:44 PM   #4
Tynee
I miss this truck.
Tynee's Avatar
Also trace the wiring back from the dimmer switch to the fuse block, seems to be a popular place for people to hack into the wriing, and not get it connected well afterwards.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 06-28-2005, 07:30 PM   #5
briarpatch
briarpatch's Avatar
Check the ground wire that comes from the panel cluster. It clips onto the dash between the radio and steering wheel. I put a screw in mine because it wasn't grounding very well. If it isn't making a good connection it will cause a multitude of electrical problems...
'67 C/10, '04 Tahoe
briarpatch is offline   Reply With Quote
Old 06-28-2005, 08:50 PM   #6
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Yeah to what they said, check tthe "bright" switch, I used to hava a truck that the if I pulled the switch once the parking lights would come on (supposed to) but when I pulld on it a second time the lights would come on briefly and go out, it turns out the switch was bad and had a lot of play, if I push the switch in juts a bit, then the lights would come on, I never changed that switch after I knew the right wiggle
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 06-28-2005, 09:03 PM   #7
Gordo
If all that stuff seems to check out, plug in a known good or new headlight bulb just to be sure it's not a pair of bad bulbs.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-29-2005, 12:12 PM   #8
Nightrider
Nightrider's Avatar
thanks guys!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 06-29-2005, 01:29 PM   #9
KEH
Better late than never
KEH's Avatar
I just replaced both of mine because the brights were blown. Both at the same time. I was having alternator problems a while back and maybe that had something to do with it.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
