Old 06-28-2005, 05:31 PM   #1
Russell
Professional Grade
Russell's Avatar
auto trans linkage?
Hey guys!
How does the linkage for an automatic hook up in these trucks? I tried to use my old 2wd linkage, but the part that should be put into the frame hits the rear front spring hanger.
I've got a 355 / TH400 combo in my truck. The TH400 is for a 2wd as I am gonna be running a divorced case, but I don't think that should make any difference...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-28-2005, 05:35 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
the part that goes to the frame is differant on a 2 wheel than a 4x4 you need the 4x4 part its made to bolt on differant
tnblazerk5 is offline   Reply With Quote
Old 07-05-2005, 01:55 AM   #3
super72bb
I also heard that the shift rod is a little longer than the 2wd ones. My guess is because the engine and tranny are moved back a bit in the 4x4's compaired to the 2wd.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 07-06-2005, 01:33 AM   #4
Russell
Professional Grade
Russell's Avatar
Well, I figured out my problem today
Apparantly, the PO of my frame removed the auto trans bracket that bolts to the frame, lol
However, I did run into a clearance with the shift rod to the rear hanger. I re-bent the plate on the rod, and it is all good now
