Old 03-21-2002, 02:59 PM   #1
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
Post almost a wheel stand...
today leaving school i was playin around with my truck at the light. I would rap the throttle then immediatley compress the brake, this would get the front end bouncing. When i first got my truck a long time ago i would do the same thing for my friends to show off my $0 hydros. Well, b/cuz of the torque of the engine the front right side tire pulls up the most. Way back when I could only get it bouncing, but know air. i even tried to get it bouncing up and then and nail to try to get the tires off the ground, only to spin the tires. Well today after the installation of a new cam, w/ same 295's out back I can get it to fully extend the suspension and, bottoming out the suspension, not on the ground but up in the air. So hopefully when my new M/T's arrive I will be able to get an actual tire off the ground, and tell every body my truck can do wheel stands!
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Intake 850 cfm carb Comp Cam 268/.500 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
    Put it to the floor...
-Nic
Lutz, Fl
My Team Website
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
