Old 06-28-2005, 06:25 PM   #1
Martin64
Martin64's Avatar
Won't Start...Need Help
I have a '70 C10 with a 350 ci motor. Has fuel, has spark, won't start.
In March while I was home on leave the truck started and ran fine. Went to take my son to school, truck started and ran for about 30 seconds and quit. Now that I'm home I checked spark. It has spark all the way to the plugs. Has a little under 1/2 tank of gas. Pulled fuel line off at carb, turn motor over and shot fuel about a foot out the end of the hose.
Any ideas?
Anyone in San Diego area wanna give 'er a look? I'm located in El Cajon just off I-8 and Hwy 67.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 06-28-2005, 07:57 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
id start by dumpin a bit a gas down the carb. perhaps your needle is stuck.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 06-28-2005, 08:29 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I agree with dave. If it ran when you parked it, and it sat for a while, there is a good chance that the fuel in the carb is all gummed up.
What color was the spark, and did you crank it long enough to see more than one spark?
Old 06-28-2005, 08:54 PM   #4
Martin64
Martin64's Avatar
The spark looked a good...... I'll run some gas through the top and see what happens. It has sat for quite a while....pretty close to 9 months while I was deployed. But it ran fine the day before it died in March, that's what has me baffled.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-28-2005, 09:46 PM   #5
Martin64
Martin64's Avatar
Ok, it starts when I pour gas through the top but won't stay running. And, just to re-verify, I checked the fuel pump again and it's working just fine.
I checked Kragen for another 2 barrel it's about $120.00, but it's a manual choke (instock).
What are my options? I know it's probably hard to answer "sight unseen", but throw 'em out there and let's see what comes out. You guys have way more experience than I do. I'm pretty handy with motorcycles, but trucks, I'm just learning about this one.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-28-2005, 10:31 PM   #6
Longhorn Man
myself...since I am too cheap to buy a new carb, and too scared to take one apart (onless there is fundage for a replacement) I'd remove the carf, and drain all the fuel out of it, then full it with berryman's B12 chem tool carb cleaner and let it sit overnight. Then empty it, and fill it again but only for a little while as you clean the outside with the cleaner and a toothbrush. Then reinstal on truck and crank it over a few times to fill, then it'll probably fire.
If this doesn't work, then you have no choice but to open it or replace it.
Old 06-29-2005, 12:47 AM   #7
Martin64
Martin64's Avatar
I'll give that a "go" in the morning. I've had lots of motorcycle carbs apart so I'm not too shy about ripping into a carb but I'd just as soon not if I don't have to. I don't use too much carb cleaner on bike carbs because it tends to eat up any small rubber o-rings it comes in contact with and I wasn't too sure if there was anything that I would destroy by using carb cleaner.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-29-2005, 11:59 AM   #8
panhandler62
Java Mechanic
panhandler62's Avatar
Your float is probably stuck in place with gum. The truck ran until the bowl emptied, runs when you fill it up with a cup, but if the float is stuck at the top the bowl will never fill.
I would start there.
panhandler62 is offline   Reply With Quote
Old 06-29-2005, 03:00 PM   #9
Martin64
Martin64's Avatar
Thank You gents. It was a stuck float.....runs like a charm...
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-29-2005, 06:05 PM   #10
86SILVERADO
86SILVERADO's Avatar
You really should at least replace the needle and seat. When it dries up in there and the needle varnishes itself to the seat like that it usually has a little ring left around it even if you get it unstuck. it can prevent the needle from seating properly in a very unpredictable sort of way. This is not good when your float bowl overflows when you least expect it and dumps loads of fuel down the intake into the motor. 10 bucks for a carb kit and all you really need to replace is the needle and seat and the airhorn gasket. Cheap insurance against possible major engine damage.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
