I'm working on the brakes of a 69 lwb, converted to 5 lug, power boster.
Is there anyone running a 3/4ton brake booster on a 1/2ton lwb truck? I just can't seem to the the right kind of brake peddle feel. Wanted to know if the 3/4ton booster would make any difference. Thanks, Matthew
69 swb stepside, rebuild and upgrade in progress Last edited by matt67350; 06-28-2005 at 07:37 PM. |
We are using a 3/4 ton brake booster and master cylinder on a 1/2 ton LWB
truck and it works great. It is not "touchy" but it certainly will stop when you step on it. Jim |
My conversion to pwr brakes included a 3/4 ton booster and it works awesome, I believe I had to use the linkage rods from the 3/4 ton truck to make it work. I don't know what the difference is if any between 1/2 and 3/4 ton booster as far as braking force, but it darn sure stops better than with the ol' "manuel" brakes!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Thanks guys,
Just needed the backup on the change over.
69 swb stepside, rebuild and upgrade in progress Last edited by matt67350; 06-28-2005 at 11:24 PM. |
