Old 06-28-2005, 09:44 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Door latch question
My door seems to move and make much more noise than the normal noise. I realize that there will be some noise due to the body flex. I think maybe the latch isn't latching properly. how do I check that?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-28-2005, 10:23 PM   #2
jhow66
jhow66's Avatar
If it is staying shut, it is latching ok. Try pulling on it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-29-2005, 09:27 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
How are your body mounts? If they are shot, that could add to the problem.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-29-2005, 10:05 AM   #4
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
squirt the latch with some white lithium grease.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 06-29-2005, 10:37 AM   #5
mastercraftkpk
It is also pretty common for the hinges to wear over the years. If the bolts holding the hinges to the body and to the door itself are tight, pull up and down on the door and watch the hinge. If there is enough play in the hinge to allow the door to move more than 1/8'' then you need to replace the hinges.
If your hinges are OK, next check for rot/rust in the area immediately below your hinges. If this area is week, your doors will constantly move.
If all of the above things are OK, you may need to simply adjust the door striker itself so that it lines up w/ your door latch better.
They are not "insurgents"...they're vermin, cowards, and terrorists.
Egon..." I think that they are more interested in my epipedimus."
mastercraftkpk is offline   Reply With Quote
Old 06-30-2005, 07:12 PM   #6
JayDubBlazer
go cyclones
I think it is a combination of the hinges and the body mounts. Could somebody refresh me on why i don't want to have the poly ones, but the rubber ones, and where I can get them
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 06-30-2005, 08:25 PM   #7
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
See this thread >> here <<
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 07-01-2005, 02:48 PM   #8
mastercraftkpk
I used black poly body mounts that I bought from Chevy Duty. Had no problems w/ them. Do not be concerned if you need some shims to get things to line up. Blazers/trucks were often shimmed from the factory.(but only a few shims, not like 1/2'' worth)
In fact, my '94 blazer had shims from the factory.
Old 07-02-2005, 03:35 AM   #9
JayDubBlazer
go cyclones
Well i order a new door latch, after close inspection I thing that is the cause for 80% of the noise. Ill let you know how it goes. Hopefully i will be able to fix it.
Wes
PROJECT OLE GREEN
2017 Silverado LT
