progress on my interior
finally starting on the cosmetics-thought i would share some pictures
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts- |
Geez, that first pic looks almost exactly like my truck did when I started, only I didn't have a seat or a steering column.
I got a bench seat baby, you don't have to sit over there. |
It looks like you converted the gas pedal to a 71-72 type? I have a setup from a 72 and wondered how hard it would be to swap this into my 70..
"You can take the man out of PA, but you can't take PA out of the man" |
That has to be the largest hole I have ever seen cut into a the dash, what was that for a flat screen TV??? What did you cover it with? Looks much better!!! Good Job.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed ![]() Last edited by chevyfarmer; 06-29-2005 at 09:08 AM. |
More Cowbell....
In that first pic that shows the bedside & door, I was wondering that type of paint scheme you were running....then I realized it was the shadow from the privacy fence!!! DUUUUHHHHHH!!!
Hey, do you have access to a welder? Or a buddy that welds?? I can send you a center section to get the dash back into shape. It would repair the radio hole and the ashtray hole....unless you are planning to install a small fire-resistant SAFE or something. (j/k).
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#6 | |
II Timothy 4:2
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
my cab is a 67 and it came with accelerator rod and it mounted on the outside of the cab,the cable bracket mounts inside and i put my kickdown switch there,on the hole i actually widened it from previous,the guy had scabbed a piece of thin sheet metal over the original radio slot that had been bugard up,i used a piece of aluminum diamond plate that i had ,made it as a removeable so i can put me a radio in there and some extra guages,i need to get a shifter yet,probably a( hurst indy stick),on the outside im going with a satin black and some wheels.
#8 | |
More Cowbell....
thanks for the replies-this truck has nine lives-hahaha,it actually has flames underneath the primer,i think they primed it before the owner i got it from,i dont have access to a shop so im kinda doing it out in the driveway,had to rebuild the doors-regulators,latches and locks-everything is getting up to snuff, its not going to get a ground up resto but should be fun to drive,look decent and be safe
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#11 | |
F.A.S.T. president
![]() Join Date: Sep 2003
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
collector of vintage rust
Major improvement.The red will look good w/ the black.......
I didnt notice the fence either, and thought you must have masked it off w/ pinstriping and sprayed it w/ a bug sprayer!......lol |
#13 |
Designated A-hole!
Looks a lot better. Go ahead and mount a TV in that hole in the dash.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#14 |
Saving 1 truck at a time!
ROFLMAO...I thought that was a pretty even run pattern at first, then I thought it was masking then I read PUTTER's post. In this neighborhood a privacy fence is a 14 ft concrete wall...a "Good Neighbor" fence, on the other hand is 14 ft chainlink with razor wire on top...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
